Home > My Defender > Grafty's Td5 90
Page 74 of 124 <123 ... 737475 ... 122123124>
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
What's project blinky?? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #726018 29th Aug 2018 9:09am
grafty99
If you search 'project binky' or 'bad obsession motorsport' into YouTube it will bring up their channel. I'd highly recommend starting from episode 1. Their fabrication work is amazing Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #726019 29th Aug 2018 9:13am
gazman
Thanks just seen the 1st episode 2014 - current ..... 2003 defender td5 90 (my car)
Post #726116 29th Aug 2018 6:13pm
L110CDL
You will be hooked now Wink Clayton.
Keeper.
Post #726179 29th Aug 2018 8:54pm
grafty99
I've just caught up to episode 18. What a coincidence about the wipers Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #726231 30th Aug 2018 9:08am
Procta
how is the head gasket job going on? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #726304 30th Aug 2018 6:50pm
grafty99
New head should be here tomorrow or Monday. Just doing the prep. Going to whip the sump off tomorrow and check the oil pump bolt and clean it out. Put it all back together then head off to the Nürburg Ring Whistle
And I'm not joking. The ferry is booked Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #726309 30th Aug 2018 7:12pm
Procta
Shocked very brave man Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #726343 30th Aug 2018 8:44pm
grafty99
Things progressing with putting the head back together. Doing all the prep work for bolting it all down tomorrow. Block is cleaned and prepped. Glow plugs are in and FPR fitted with new gaskets etc.
So tomorrow I'll be hopefully completing the rebuild and getting round to the other side of the workshop. The plan there is to get it onto the ramp then remove the sump to check the oil pump sprocket and clean it out.
Then fresh oil, filters and coolant and it would be drivable by the end of the weekend Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #726507 31st Aug 2018 7:17pm
L110CDL
Great move forward, best of luck for you to get to the ferry on time Wink
Good you caught up on project Binky, it was a spooky moment when i saw you doing your wiper mod Shocked Thumbs Up Clayton.
Keeper.
Post #726528 31st Aug 2018 8:59pm
barbel jim
Thumbs Up
Glad it's going to plan
Post #726553 31st Aug 2018 10:12pm
grafty99
1990 Vogue SE
Post #726554 31st Aug 2018 10:15pm
grafty99
Everything is now back together. Tomorrow I'll be taking the sump off to check the oil pump sprocket bolt and then replacing all the fluids in preparation for the Nürburg Ring.
I've turned the engine over by hand many, many times and am confident that everything is clearing so tomorrow I'll be getting it running and then taking it for a drive Thumbs Up
1990 Vogue SE
Post #726672 1st Sep 2018 5:22pm
Procta
Fantastic Grafty Thumbs Up One question, what will happen to this? since you have the classic range rover Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #726677 1st Sep 2018 6:02pm
grafty99
The defender will become my daily again and then I can continue the restoration of the range rover - getting it to how I want it instead of getting it complete to use. So partial strip down again for final body work and cosmetic stuff Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #726686 1st Sep 2018 7:32pm
