![]() | Home > Technical > Mantec Tufflift and Wheel Carrier fitting |
The ones I’ve seen have a metal plate on the ends of the straps of the tufflift to bolt into the holes under the the wheel bolts. Ray
That one work with td5 wheel carrier
![]() Click image to enlarge Last edited by dorsetsmith on 23rd Aug 2018 8:19pm. Edited 1 time in total |
http://www.defender2.net/forum/topic44147....c+tufflift http://www.defender2.net/forum/topic53350.html |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
^^^ thanks for the links. Not sure how I missed them...
![]() For anyone else looking at the second link, here's the page pointer http://www.defender2.net/forum/topic53350-240.html Seems like I just need to make a couple of clamps to hold the straps on the Mantec carrier. Easy job. Although I note that those that have used the Tufflift imply its not that brilliant...;-( I'll give it a go, nothing to lose. cheers simon |
Mine seems to work fine, and makes lifting the wheel back on much easier (it's heavy, 255/85 KM2 on Blindo, and much higher than standard).
Before the Tufflift putting the thing back on a serious effort. Now it is easy. ![]() Click image to enlarge |
I've got 255/85s KM2s too, on Freestyles and I can barely lift it, let alone align the studs and fit the nuts. So I'm hoping the Tufflift helps...it cant be any worse..!
cheers simon |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
Are they still available now that Mantec have gone? Getting my spare on and off the Manted carrier manually is going to do for my back one day. 2007 110 TDCi Station Wagon XS
I doubt it, I was given mine. There are exMOD versions (new/old stock) on eBay for around £100.
cheers simon link here:- https://www.ebay.co.uk/itm/Land-Rover-Wolf...SwUH5aV275 |
Flatdog have them on the shelf, £45 delivered, unless I bought the last two
^^^ have you fitted them yet..?
Ive fitted mine and while it makes a difference getting the wheel up to the carrier, it isn't perfect by a long way. But every little helps at my age.. ![]() cheers simon |
I just fitted it now. Seems to work ok. I set it so you have to lift the wheel a tiny amount to get it on the carrier. Only concern is the straps marking the front face of the wherk. 2007 110 TDCi Station Wagon XS
Mines pretty much the same, it needs a lift to get it onto the wheel studs, but at least it's 90% of the way there.
I don't think the straps on mine would do much, if any, damage to the face of the wheel. It'll be a lot less than a days laning anyway... ![]() Cheers Simon |
