Home > Technical > Mantec Tufflift and Wheel Carrier fitting
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Hi,
I have a Mantec Tufflift (helps load spare wheel onto wheel carrier) and a Mantec wheel carrier (arrived today).
I have searched high and low for instructions on how to attach the Tufflift to the carrier. I asked in a previous thread (Anoraks build thread) and it was suggested that the wheel carrier would have holes to allow fitting. I cant see how it would fit.
See photos attached.
Any ideas gratefully received...Wink
cheers
simon
Post #725073 23rd Aug 2018 6:35pm
mk1collector
The ones I’ve seen have a metal plate on the ends of the straps of the tufflift to bolt into the holes under the the wheel bolts. Ray
My build thread
Post #725095 23rd Aug 2018 8:06pm
dorsetsmith
That one work with td5 wheel carrier
Post #725097 23rd Aug 2018 8:10pm
dorsetsmith
http://www.defender2.net/forum/topic44147....c+tufflift
http://www.defender2.net/forum/topic53350.html
Post #725098 23rd Aug 2018 8:12pm
couplands
^^^ thanks for the links. Not sure how I missed them... Embarassed
For anyone else looking at the second link, here's the page pointer http://www.defender2.net/forum/topic53350-240.html
Seems like I just need to make a couple of clamps to hold the straps on the Mantec carrier. Easy job.
Although I note that those that have used the Tufflift imply its not that brilliant...;-( I'll give it a go, nothing to lose.
cheers
simon
Post #725136 24th Aug 2018 12:01am
Mine seems to work fine, and makes lifting the wheel back on much easier (it's heavy, 255/85 KM2 on Blindo, and much higher than standard).
Before the Tufflift putting the thing back on a serious effort. Now it is easy.
Post #725165 24th Aug 2018 8:34am
couplands
I've got 255/85s KM2s too, on Freestyles and I can barely lift it, let alone align the studs and fit the nuts. So I'm hoping the Tufflift helps...it cant be any worse..!
cheers
simon
Post #725168 24th Aug 2018 8:46am
Bluest
Are they still available now that Mantec have gone? Getting my spare on and off the Manted carrier manually is going to do for my back one day. 2007 110 TDCi Station Wagon XS
Post #725174 24th Aug 2018 9:11am
couplands
I doubt it, I was given mine. There are exMOD versions (new/old stock) on eBay for around £100.
cheers
simon
link here:- https://www.ebay.co.uk/itm/Land-Rover-Wolf...SwUH5aV275
Post #725175 24th Aug 2018 9:14am
Bluest
Flatdog have them on the shelf, £45 delivered, unless I bought the last two Thumbs Up 2007 110 TDCi Station Wagon XS
Post #726119 29th Aug 2018 6:17pm
couplands
^^^ have you fitted them yet..?
Ive fitted mine and while it makes a difference getting the wheel up to the carrier, it isn't perfect by a long way.
But every little helps at my age..Wink
cheers
simon
Post #726120 29th Aug 2018 6:30pm
Bluest
I just fitted it now. Seems to work ok. I set it so you have to lift the wheel a tiny amount to get it on the carrier. Only concern is the straps marking the front face of the wherk. 2007 110 TDCi Station Wagon XS
Post #726135 29th Aug 2018 6:55pm
couplands
Mines pretty much the same, it needs a lift to get it onto the wheel studs, but at least it's 90% of the way there.
I don't think the straps on mine would do much, if any, damage to the face of the wheel. It'll be a lot less than a days laning anyway... Shocked
Simon
Post #726145 29th Aug 2018 7:19pm
