Home > Technical > td5 rev counter
Page 5 of 10 <12345678910>
Martin
Site Admin
As I said earlier in the thread you can't read the voltage with a multimeter, you need a pull-up which is in the Rev counter's circuitry.
You can read it (or put a scope on it) with the rev counter connected as then the rev counter is pulling up the signal.
If your multimeter has a frequency setting you can also try it (gauge connected still) but whether you get a reading depends what it's cutoff frequency of the meter is.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #723115 12th Aug 2018 8:13pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Just thought I'd double check as Clive said it may be possible. I've emailed smiths to see if they have a solution.
Post #723126 12th Aug 2018 9:17pm
dobbo
United Kingdom 2004 Defender 130 Td5 HCPU Chawton White
Hi guys just wondering if you can help and advise with my installation of my rev counter for my 2004 td5 defender. I'm getting 1.3 volts from pin 19 in the ecu I was told I should get 6 volts, the gauge is wired in as per instructions from CAI and it's doing a sweep with ignition on returning to zero and staying there with engine running.
Any help appreciated I did think my multimeter may not pick up the pulse but not sure now.
Paul
Post #723722 16th Aug 2018 8:22am
LandymanStefan
That makes 3 of us then
Post #723731 16th Aug 2018 9:11am
Martin
Site Admin
Sounds like an issue with the rev counters themselves Sad
Anyone local to any of you with a known working Td5 rev counter who could do a quick swap and test?
I have one but a bit far to nip round to check Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #723743 16th Aug 2018 9:48am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I'm beginning to wonder if the tachos in question are set up correctly, the instruction sheet indicates that there is an 8 way DIL switch inside to program it to the engine parameters, the sheet isn't specific about it but I wonder if one of those switches determines a pull-up on the input?
Post #723744 16th Aug 2018 10:16am
Martin
Site Admin
Genuine Td5 ones don't have any switches to configure.
Any photos of part number labels and/or the back of the counters people have received from CAI? Happy to compare against my genuine one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #723746 16th Aug 2018 10:24am
Clive
The instruction sheet says "... programmed via eight dil switches located beneath the grommet to the rear of the instrument ..."
I can whip mine out, (the tacho Embarassed ) and take a picture if it helps.
I should just add, mine worked straight away, "out of the box".
Post #723750 16th Aug 2018 10:33am
LandymanStefan
When I messaged them I got this, I haven't had a chance to remove the rubber bung and play with the switches yet but gerrardtd5 told me he tried it and had no luck
Post #723752 16th Aug 2018 10:36am
Martin
Site Admin
Clive wrote:
I can whip mine out,Laughing
Sounds a bit like CAI may have shipped standard diesel type counters with Td5 dials Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #723753 16th Aug 2018 10:38am
LandymanStefan
But if Clive's worked straight from there then that's not the case.
Unless our batch is different to Clive's??
Post #723754 16th Aug 2018 10:39am
Martin
Site Admin
Sorry missed that in Clive's post Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #723756 16th Aug 2018 10:41am
Clive
Maybe mine was just set up correctly originally and missed on the others?
Anyway, here's the back of mine, (cropped from earlier picture,) I'll need to take the binnacle out to check the switches, that will have to wait for now I'm afraid.
Post #723759 16th Aug 2018 10:50am
Martin
Site Admin
Totally different to the genuine one:
2015 D90 XS SW
Post #723765 16th Aug 2018 11:16am
dorsetsmith
how did Exclamation Question
Post #723780 16th Aug 2018 12:19pm
