Home > Maintenance & Modifications > Backlash sorted
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Backlash sorted
Had gearbox output shaft replaced today simply as a precaution
Turns out to have been just in time
There was significant wear - it seems to have been replaced before I bought it @40k miles and has done 75k since
This was the replacement
And the final touch
At 116K miles she is as tight as new! Thumbs Up
Post #722500 9th Aug 2018 12:47pm
jst
If those rears wear now there is a serious problem! Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #722519 9th Aug 2018 2:52pm
Re: Backlash sorted
shropshiredefender wrote:
I reckon that technique would work quite well for the output adaptor shaft joint too.
Incidentally did you weld the inner face as well, or just the outer?
Post #722527 9th Aug 2018 4:10pm
shropshiredefender
Just the outer and a quality weld (not done by me and my stick welder!)
Would, I'm sure, work with the output shaft but I wasn't prepared to have that done when the Ashcroft kit was available and seems a more elegant solution.
Post #722530 9th Aug 2018 4:20pm
Cupboard
do the fronts wear in the same way the rears do?
Post #722724 10th Aug 2018 5:37pm
shropshiredefender
Personally over 5 different Land Rovers and well over 500k miles I've only had problems with the rears.
Post #722725 10th Aug 2018 5:44pm
miker
I'll be honest, I have been tempted to weld my rears up to help with my backlash. I'd swap to one piece if I could but I'd have to replace the Salisbury axle!
Post #722731 10th Aug 2018 6:32pm
shropshiredefender
The chap who looks after my Land Rover has 2 110s with Salisbury diffs. He welded the half shafts on both of his several years ago, the one pictured is used for heavy off roading and towing, the other is his daily driver.
Post #722734 10th Aug 2018 6:43pm
zsd-puma
They can do, but there's not much you can do with them, as unlike the rears there is a CV joint rather than a half shaft, so if you welded it, you'd make it extremely difficult to replace the CV joint if it failed.
Post #722742 10th Aug 2018 7:29pm
I've never (yet) had a problem with the fronts, but have got through a succession of rears. I think the fronts benefit from a certain amount of lubricant from the swivel housings, whereas the rears are as standard sealed from the axle tube and hence unlubricated.
Post #722769 10th Aug 2018 9:37pm
LR90XS2011
interesting, at about 18000 miles my rears were starting to rust and were stuck to the shafts, had to use a mallet to get them off to remove them and grease them, 6000 miles later they were as I had left them with loads of grease in the cap and wet splines that slid nicely.
The fronts on both occasions were clearly in a different state and looked all lovely and lubricated.
So I expect what Blackwolf says is true
I have added removing wheels and checking them to my annual (3000mile appox) service schedule DEFENDER 90 TDCI XS,
Post #722777 11th Aug 2018 5:50am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
My td5 has one piece rear shafts, was this a upgrade by land rover to stop this or has someone changed them?? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #722799 11th Aug 2018 8:07am
dorsetsmith
no as fitted LR factory to 2003 model in 2005 to 2006 two peace rear shaft fitted at LRJ and to end production
Post #722803 11th Aug 2018 8:17am
I think the rear gets a lot more weather around it, and those basic rubber caps are not waterproof and can trap water in.
I'm sure I had water into mine, as my issues started after passing a Ford in early spring.
Same thing with the Prop UJ's the nipples are fine but if ones missing the wet will go straight in.
The front axle avoids most road water but gets splashed up more at the back.
The output adaptor shaft is so commonly un-lubed as BW explained to me a few years ago it's no surprise they wear badly.
When I last had a clutch change it was okay, but I got them to lube it before putting back.
I'm sure that it wasn't originally! Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~
I got’ love for Britain, I got’ British pride’. 🇬🇧
Post #722828 11th Aug 2018 10:54am
Grenadier
What warning signs should we (who've yet to join the backlash club) be looking for? Sounds, feelings, visual? Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #722829 11th Aug 2018 11:07am
