Home > Puma (Tdci) > Noise from Air Intake
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
I have a 2012 2.2 110 USW that drives and sounds superb. With this current heatwave I've been doing a lot of miles with the drivers window down. With the window open I sometimes here a sort of 'throaty' sound coming from just in front of drivers door, presumably the air intake. The sound changes pitch now and again with an occasional minor 'cough' especially at lower revs and when changing gear or accelerating and decelerating. At full driving speed in 5th or 6th gear sound is constant and smooth. The sound cannot be heard with window closed. Is this normal?? Bow down Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721111 2nd Aug 2018 7:23pm
UtilityTruck
Definitely not the viscous fan kicking in? It’s quite a loud, roaring/rushing noise. I find mine doesn’t kick in much but is most likely heard after driving at higher road speeds and then slowing down, e.g for a junction or similar.
Failing that...
When did you last change the air filter? Perhaps you’ve got some debris in there? It’s simple to take the lid off and pop out the filter to take a look 2014 Keswick Utility 2.2
Post #721116 2nd Aug 2018 7:44pm
sloderby1
My 2015 90 does very similar - as you say, more noticeable with the recent requirement to have windows open.
I guess you've not got aircon either then!
Post #721122 2nd Aug 2018 8:09pm
zsd-puma
Sprinters used to do that. It was the DPF regen cycle.
Post #721129 2nd Aug 2018 8:52pm
Sammyboy
I have air-con but like window open sometimes Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721195 3rd Aug 2018 10:02am
jst
Ferrari going past? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721202 3rd Aug 2018 10:46am
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721203 3rd Aug 2018 10:52am
Sammyboy
Their not that fast Rolling with laughter Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721204 3rd Aug 2018 10:52am
Caterham
it's not a simples case of the air filter lid isn't fitted properly?
easily done (or not as the case may be)>
Post #721245 3rd Aug 2018 4:17pm
Siwynne
Mine does this. More noticeable when I put a new filter in. It also sounds different when I use a non genuine air filter. Mine is in properly and the air box is sealed. I just put it down to Induction noise. I do know the cough you talk about though.
Post #721251 3rd Aug 2018 5:18pm
Sammyboy
That's exactly what it sounds like and what I thought it was. I just thought I would ask others of their opinion and experiences. Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721253 3rd Aug 2018 5:21pm
Roy5695
Mine does this, especially when you’re between 1500 and 2000RPM. Pretty sure it’s the recirculating valve/turbo noise. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #721265 3rd Aug 2018 6:40pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
its quite normal its just air pulling in the air box you will get different noise depend at what your accelerating at and constant at a set speed Smile
Post #721636 6th Aug 2018 8:36am
Sammyboy
Thanks Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721698 6th Aug 2018 11:56am
Sammyboy
All fixed. Removed air filter, cleaned air box and hoovered filter (would have bought a new one but going for a full service in two weeks) , sound gone and runs even better than she did before with no unusual noises. Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #722034 7th Aug 2018 7:17pm
