![]() | Home > Puma (Tdci) > Noise from Air Intake |
| UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463
Definitely not the viscous fan kicking in? It’s quite a loud, roaring/rushing noise. I find mine doesn’t kick in much but is most likely heard after driving at higher road speeds and then slowing down, e.g for a junction or similar.
Failing that... When did you last change the air filter? Perhaps you’ve got some debris in there? It’s simple to take the lid off and pop out the filter to take a look 2014 Keswick Utility 2.2 |
| sloderby1 Member Since: 08 Feb 2018 Location: Derby Posts: 20 |
My 2015 90 does very similar - as you say, more noticeable with the recent requirement to have windows open.
I guess you've not got aircon either then! |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
Sprinters used to do that. It was the DPF regen cycle.
| Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121
I have air-con but like window open sometimes Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
Ferrari going past? Cheers
Their not that fast
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
it's not a simples case of the air filter lid isn't fitted properly?
easily done (or not as the case may be)> |
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 625
Mine does this. More noticeable when I put a new filter in. It also sounds different when I use a non genuine air filter. Mine is in properly and the air box is sealed. I just put it down to Induction noise. I do know the cough you talk about though.
That's exactly what it sounds like and what I thought it was. I just thought I would ask others of their opinion and experiences.
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
Mine does this, especially when you’re between 1500 and 2000RPM. Pretty sure it’s the recirculating valve/turbo noise. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617
its quite normal its just air pulling in the air box you will get different noise depend at what your accelerating at and constant at a set speed
Thanks
All fixed. Removed air filter, cleaned air box and hoovered filter (would have bought a new one but going for a full service in two weeks) , sound gone and runs even better than she did before with no unusual noises. Thumbs Up Discovery 4 HSE
