Home > Technical > td5 rev counter
Page 3 of 10 <12345678910>
Screbble
Very nice job Clive Thumbs Up
And excellent research and results on the part of other forum members Thumbs Up
Post #720914 1st Aug 2018 9:40pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
What a beauty!
I think mine is at home but won't know till the weekend as I work away from home.
Luckily for me I had previously checked if I had the grey/white cable for the tacho from pin 19 behind the dash and to my surprise I did so my wiring job should be much simpler than yours.
Post #720923 1st Aug 2018 10:45pm
If (like Stefan above) you already have the grey wire in place in the loom, then how do you connect to it (seeing as it's wired into a plug)
There must be a jumper lead out of the warning light cluster somewhere to link to the rev counter?
Post #720949 2nd Aug 2018 7:39am
Martin
Site Admin
Get a terminal for the matching grey connector which is on the instruments loom (PaulMc does the terminals).
Or cut the white/slate and extend to the rev counter directly or add your own connector.
The warning lights are connected separately through two smaller black connectors - these don't have any signals on them to do with the instruments.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #720954 2nd Aug 2018 8:08am
OK cheers. I just wondered how it was done from the factory. if they had a jumper loom available or the Td5 dash had a separate rev counter sub-loom hanging off the main one
Post #721254 3rd Aug 2018 5:22pm
LandymanStefan
Just waiting for my connector from Paul mc now... got the rev counter in and it powers up just haven't got the signal connected yet. Does anyone know what voltage to expect from the signal output? I checked with a meter and I was only getting 0.19v when I revved it a little bit it would roseto around 0.3 but I didn't give it a bootfull. Seems a bit low to me....
Post #721365 4th Aug 2018 8:21am
Martin
Site Admin
You won't get a measurable reading with a meter like that due to the way the ECU generates the signal.
It's not a varying voltage signal, it is varying frequency, and requires a "pull up" which is done in the rev counter.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #721368 4th Aug 2018 8:41am
LandymanStefan
Ah right I'll have to wait until I get my connector then, although it didn't come today so I won't be able to do it until next weekend Big Cry
Post #721371 4th Aug 2018 9:07am
PaulMc
Stefan,
Sorry to hear that your crimped terminal and cable wasn't delivered today Sad
I did post it yesterday, by 1st class post.
Anyway, when it does arrive, you'll need to unlock the connector housing before you can insert the new terminal.
This picture sequence shows a connector from the same series -
Lift latches on each end of terminal lock (you'll only need to do this for one row)
Open terminal lock
Insert terminal(s), crimped side towards outer side of connector housing
Close terminal lock
Engage latches
. Paul.
Post #721421 4th Aug 2018 3:08pm
LandymanStefan
Nooo don't be sorry about it not arriving! I wasn't expecting it to in one day but I was hoping it would. Can't thank you enough for the instructions and the connector!
The forum working at its best Very Happy Very Happy
Post #721427 4th Aug 2018 3:42pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Just found this post. Will look into it once I'm back from my holidays. Top work! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #721450 4th Aug 2018 5:37pm
GerardTd5
Netherlands 2001 Defender 90 Td5 CSW Epsom Green
Hi,
Try to connect the tachometer. In this case it is a 90 Td5, my 2001, with abs and tc. If I have understood correctly, the white / black wire must be connected with yellow / pink wire that runs from pin 19 to the abs module. My question is whether it is the yellow / pink wire as marked on the photo with the blue circle.
Thanks
GerardTD5
Post #721730 6th Aug 2018 2:43pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
The yellow/pink wire referred to goes from C0658-13 on the ECU to the speedo, it appears to carry the road speed pulse signal, not the engine speed from C0658-19 to ABS.
Confusing to have more than one of the same colour wires with different functions Confused
Looks like you're stuck with running the complete new wire from ECU to Tacho Sad
Post #721768 6th Aug 2018 5:48pm
GerardTd5
Clive, that's what it looks like. I had hoped it was easier; I misinterpreted the pictures of Paul MC and LandymanStefan.
What I can still do is see which color wire pin 19 is and try to find behind the dashboard and then connect it to the white / black.
Thanks anyway.
GerardTd5
Post #721781 6th Aug 2018 6:35pm
Clive
Unfortunately, the wire from pin 19 to the ABS module is also yellow/pink, however, with the ABS controller being under the seatbox along with the engine ECU, that connection doesn't go outside of the seatbox.
That's what I meant about confusion over the same colour wires with different functions.
Post #721786 6th Aug 2018 6:51pm
