Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 1 of 35 123 ... 333435>
DSC-off
For survey results of 168 vehicles, as of June 2019, go to page 9 of this thread.
Hello All Puma Defender owners, please take part in this survey in an effort to understand the extent of the problem with gearbox output shaft failure. Even if you've not had a problem, we need to know how long the 'good' ones last!
This is a survey you will get useful info from. It will be on the forum so everyone here can see the data and interpret it for their own use. Discussion on the results will be welcome.
Please answer the following 4 or 6 simple questions, and feel free to add comments.
Thanks,
Jason
1, vehicle year of manufacture
2, engine type 2.4 or 2.2
3, is the Defender still running with the original output shaft? (Y/N)
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running.
If the shaft has previously failed, please answer 5 & 6.
5, Has an Ashcroft modified part has been fitted? (Y/N)
6, vehicle milage at the second failure, or milage if still running.
Repeat questions 5 & 6 for more than two shaft failures.
Post #717236 11th Jul 2018 10:48pm
DSC-off
To start us off,
1, vehicle year of manufacture 2015
2, engine type 2.4 or 2.2, 2.2
3, is the Defender still running with the original output shaft? (Y/N) Y
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. 18 000 miles
5, Has an Ashcroft modified part has been fitted? (Y/N) Not applicable
6, vehicle milage at the second failure, or milage if still running. Not applicable
Comment. Still on original shaft at 3.5 years old, 18000 miles, no noticeable driveline noise or issues.
Post #717239 11th Jul 2018 10:56pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
1. 2008
2. 2.4
3. Don't know. I havent changed in during my 3 year ownership
4. No failure (as far as I am aware) now 31,000miles
Post #717246 11th Jul 2018 11:44pm
MK
1. 2007
2. 2.4
3. Y
4. 55k miles Puma 110" SW
Post #717249 12th Jul 2018 12:02am
Oz Paul
Australia 2012 Defender 90 Puma 2.2 SW Fuji White
1. 2012
2. 2.2l
3. Yes
4. 140,000km (87,000 miles)
Daily driver, never gets pushed too hard on or off road. My clutch is rattling so when that gets replaced I will probably get an Ashcroft output shaft fitted.
Post #717255 12th Jul 2018 4:41am
zsd-puma
1. 2010
2. 2.4 (obviously)
3. N
4. Shaft didn't fail I replaced it with an Ashcroft kit when the clutch was done at 82'000miles as a precaution
5. Yes
6. hasn't failed again, at 87'000
Post #717256 12th Jul 2018 4:49am
rtg
Austria 2009 Defender 110 Puma 2.4 SW Santorini Black
1, 2009
2, 2.4
3, No, shaft was replaced at about 140.000km while replacing the clutch. It showed signs of wear.
4, -
Post #717257 12th Jul 2018 5:55am
justinp
2, 2.2
3, Y
4, 50K miles Now gone - 2012 2.2 110 DC XS
Post #717259 12th Jul 2018 6:56am
hornet
1, vehicle year of manufacture: 2009
2, engine type 2.4 or 2.2: 2.4
3, is the Defender still running with the original output shaft? (Y/N): Yes
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running: 137.000 miles (220.000km)
Post #717261 12th Jul 2018 7:37am
skoller
2009
2.4l
no
100,000k shaft replaced with Ashcroft. On inspection of original shaft, replacement was just in time.
Post #717265 12th Jul 2018 8:45am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
1, vehicle year of manufacture: 2012
2, engine type 2.4 or 2.2: 2.2
3, is the Defender still running with the original output shaft? (Y/N): No
4, vehicle mileage at first shaft failure, or current mileage on the original shaft if still running: 35,000miles
5, Has an Ashcroft modified part has been fitted? (Y/N) No (warranty replacement)
6, vehicle mileage at the second failure, or mileage if still running. 45,000 (still running) Keith
Post #717266 12th Jul 2018 8:57am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
2011
2.4
No
Failed at 85,000 replaced with genuine part.
2008 (mine)
2.4
No
Replaced along with clutch at 90,000 (grease nipple fitted to coupling)
Genuine part.
2015
2.2
No
Failed around 27,000 replaced with genuine part.
2010
2.4
No
Failed at 53,000 replaced with genuine part.
2010
2.4
No
(Rusty but ok) 62,000 replaced with clutch, genuine part.
2009
2.4
No
(rusty but ok) 59,000 replaced with clutch, genuine part.
All tow heavy loads for a living. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #717267 12th Jul 2018 9:12am
hank
1. 2007
2. 2.4
3. N
4. Shaft didn't fail I replaced it with an Ashcroft kit as a precaution when the clutch was done at 75,000 miles
5. Yes
6. Current mileage 79,000
Post #717268 12th Jul 2018 9:21am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
1, 2010
2, 2.4
3, No
4, 59k
5, No
6, 60K My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #717272 12th Jul 2018 10:06am
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
1, 2008
2, 2.4
3, Si
4, 220.000 Km (136.701 Millas)
Post #717274 12th Jul 2018 10:27am
