![]() | Home > In Car Electronics > The definitive Defender ICE thread |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 297 ![]() ![]() |
![]() In that case I will play it safe and go to a local audio fitting centre. Thanks for the heads up! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Do you mean you want an additional rear pair or are you currently running the front two only and nothing at the rear?
I presume you are using the factory HU (stereo) ? Do you have a standard harmonised DIN ISO connector block at the rear of the HU LR loom. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 154 ![]() ![]() ![]() |
Ive fitted a kenwood HU as there was nothing there before using the two standard plugs in the dash to make it work. i am running the front two speakers only and would like to run an additional 2 in the rear.
the HU has a load of connections invthe back but is working fine just using the 2 ISO (?) connectors that are part of the dash wiring |
I see what you mean.
Are connections present and wires connected for the rear two speaker channels? I.e. are they connected at the plug? Also. Are the wires present to the rear behind the speakers ready to be connected or currently are connected? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
![]() Click image to enlarge Thanks for the help Steve, The plug does have the speaker connections & wires for rear speakers, but they disappear in to the loom and I've no idea where they come out. I'm presuming there's a separate plug or something for the more advanced systems (not mine) that have OE amp & whatever??? Photos of mine.... ![]() Click image to enlarge ![]() Click image to enlarge |
Difficult to see but it looks as if the connections are present at the HU end.
Have you looked for the wires behind the speaker panels at the rear? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 824 ![]() ![]() ![]() |
Can anyone recommend a single DIN unit that does the following:
DAB (never managed to get FM working properly) Flip up screen with reversing camera input USB connection for MP3 files on memory stick Nice to have would be a bluetooth phone ability but only if it has a plug in remote microphone. Oh and it needs to be a sensible price (read very sensible price). Thanks in advance for any suggestions. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
What’s a really sensible price? a defender from 1984 pretending to be a puma with a touch of Range Rover
I would look at Clarion or Pioneer’s offerings.
However, you are looking at £300 to £500. 2 DIN or 1 DIN flip up aren’t cheap unless extremely basic unfortunately. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
As mine is a 1985 vintage, I don't have anything in the rear, i'm presuming there is a connection somewhere in the dash for an extension to the loom for the rear speakers in 110 & station wagon versions and I was hoping someone would know what I'm looking for. |
It has been known for the connections to be present hidden away at the front against the bulkhead. ____\We|Will|Win/___
Thanks, I'll keep looking...
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1897 ![]() ![]() |
Knowing nothing at all about ICE I think I'd like to plan a modest upgrade.
Head unit is an Alpine CDE-133BT with OEM speakers. Truck is a 2016 XS hard top. I quite fancy the Alpine subwoofer(?) behind the cubby and fancied the Alpine-SWE-1200 but I'm now thinking it's not a quick and easy total newby job? Bang for buck, what is the best thing I should do? Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
If you want to put it behind the cubbybox it’s quiet easy. If you want it in the cubbybox it’s a different story
![]() In other words. I have the same unit. It’s great!! I’ve designed a custom cubbybox which houses the alpine unit (and an extra drawer). If you want i can take a Photo. But it is a great unit which gives Some umpfff to the music. a defender from 1984 pretending to be a puma with a touch of Range Rover |
