![]() | Home > Maintenance & Modifications > School me on rear towing/recovery point options - so many! |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2377 ![]() ![]() ![]() |
That's a really cool pic
![]() ![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
The eventual solution:
![]() Click image to enlarge ![]() |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Exactly. JATE actually stands for Joint Air Transport Establishment. So long as you use quality forged rings they're plenty strong enough for recovery. The front mounting points are deliberately double plated for them. The rears should have a tube welded into the chassis rail, but not all civilian chassis have this from the factory. |
Memory is funny but I could have sworn that the jate rings on my mates 110 interfered with his rear mud guard bracket...
Edit: also, I can imagine recovery forces being more than the mass of the vehicle/4... and at more extreme angles... Not saying yay or nay, just sayin... Solved the bowel problem, working on the consonants... |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
agreed, the forces involved in recovery can be much much that just a straight pull.
Also, I doubt that landie under the chinook is using the same jate points under the vehicle. wouldnt be very stable!! |
The JATE rings are fitted to military Wolfs for the main reason of heli lifts as shown, new modifications have come out and a dual set of JATEDU rings with additional strength plates welded on the rear are now in place for vehicles that are carried by this method often. There was an article in LRO/LRM a while back
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
You have obviously never seen a chinook pilot use the full operating envelope whilst carrying an underslung load - the forces generated are more than the static load/mass of the vehicle. I'm really puzzled as to why anyone would want to put more trust in an online seller of a lump of laser cut unidentified steel than a product that has been designed & tested for vehicle specific military applications where the outcome of a failed load is far more than a red face. Maybe if they came in bright colours, was more sparkly or had more pub bragging rights; instead they just do the job, no fuss, no effort & not particularly expensive. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
That does look smart ![]() |
Well, Brendan 'identified' it and that was enough for me. Sometimes you just gotta trust things right? ... and like I said, the last time I saw JATE rings installed they appeared to clash with the mud guard brackets of the vehicle in question. I did want it in high-vis, first responder livery so people would think I was a champ but they only had bulk/batch/discount-dark-grey available - otherwise known as 'tactical' ![]() |
The drop plate is still a major plow when it's on! But it lives in a box in the rear now along with the shackle and billet/point so it's even less fussy ![]() ![]() |
Apparently it is...this is the current (2015) version: ![]() Click image to enlarge |
I've seen them fitted to the front of Vixens but can't find a photo of the rear arrangement: ![]() Click image to enlarge but the loading sheet for it shows that only one of the two Jate rings is used: ![]() and again with the RWMIK Plus: ![]() Click image to enlarge Don't suppose you have the article still? Searching through my documents, I've found the Modification Instruction for the double Jate rings and it states: "This instruction details the fitting of additional lashing eyes to the front bumper and to the rear chassis rail. This modification is only applicable to those units who would be considering transporting the equipment as internal load by Air." ![]() Click image to enlarge Last edited by Supacat on 17th Mar 2018 11:24am. Edited 1 time in total |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
Has anybody fitted one of these? I'm keen to see an installed photo.
http://www.4x4overlander.com/product/defen...ery-point/ Thanks Keith |
If people want to get an idea about forces involved in recovery have a read of Billy Vista Recovery Bible here
Now I do not expect people to get the calculator out and remember the various components of the formula every time they attach a winch/recovery strap. Yes forces can be 3 times vehicle weight so kit and recovery points plus technique need to be up to the job in hand. If doing a 'snatch' type recovery rather then a steady pull i.e. winch etc, that peak F= Ma (Force = mass x (de)acceleration) so selection of material/equipment is important. Brendan |
