Home > Off Topic > Calling Apple iOS Wizards!
Bluest
Having a major headache with a new iPad Mini 4. Can anyone help.
As is usual with a new product, it needs updating to the latest software 11.2.2. but the update fails every time with the message “Unable to verify update. You are no longer connected to the internet”. The device is connected to the net and I can browse the web fine.
It is displaying few other weird traits too. I can’t download any apps, it just repeatedly asks for the App Store password. I tried to do a factory reset, but the device freezes if I try to access the reset menu.
Things I have tried with no success:
Most of the things that Google suggests
Deleting and re-downloading the software update.
Hard reset.
Quitting all the running apps.
Re entering WiFi settings
Any suggestions? 2007 110 TDCi Station Wagon XS
Post #685488 10th Feb 2018 11:42am
discomog
If you go into SETTINGS/GENERAL/SOFTWARE UPDATE . it will immediately check the status and then give you a current status of your software version you are using (eg your software is up to date or some other message which may indicate why it is failing to update to 11.2.5) Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #685490 10th Feb 2018 11:53am
discomog
Have you switched on the toggle switch entitled iTunes & AppStore? See SETTINGS/GENERAL/TOUCH ID & PASSCODE. You will then have to enter your 4 or 6 digit passcode and then check that the toggle is switched on. Also check that you have turned on the passcode. Defender 90XS SW
Morgan Plus 8
Post #685493 10th Feb 2018 11:58am
Balvaig
Is this the only Apple device you have. If you have a MacBook or iMac, then the download is best done through iTunes . Plug the Mini in using the supplied connector using USB. The Mini should appear as a device in iTunes.
If this is your only Apple then I think you need to set up anApple ID and use that to access the app store. Downloads, even free ones cannot be accessed without an account or Apple ID.
You also should have free telephone support from Apple for the first 90 days.
Hope this is of some help.
Stephen
Post #685495 10th Feb 2018 11:59am
Bluest
It just says that an update is available (11.2.2) and do I want to download and install. If you choose to go ahead, the problem described above occurs. 2007 110 TDCi Station Wagon XS
Post #685501 10th Feb 2018 12:26pm
Bluest
Interesting, just tried this, the iPad freezes when I enter the passcode. I then have to double click the home button and quit settings to get out of it. Can't get far enough the see what the settings are. 2007 110 TDCi Station Wagon XS
Post #685503 10th Feb 2018 12:28pm
Bluest
Stephen
I've got an Mac Mini. Will try this now. 2007 110 TDCi Station Wagon XS
Post #685504 10th Feb 2018 12:28pm
Bluest
Not good news. Tried the update through iTunes connected to my Mac. Got two thirds of the way through. iTunes then flagged error with the iPad and said the update couldn't complete.
iPad is now stuck like this...
Post #685510 10th Feb 2018 12:54pm
The iPad 4 Retina has updates discontinued.
Are sure this is not the case? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #685518 10th Feb 2018 1:34pm
discomog
I think, as Stephen suggested, as the iPad Mini is brand new, I would now ring Apple Support or if you are near an Apple store take it in to them. I've only had to use Apple telephone support twice and they were excellent both times. Good luck. Defender 90XS SW
Morgan Plus 8
Post #685522 10th Feb 2018 1:49pm
Balvaig
Unplug and try a hard reset.
To perform a hard reset:
Hold down the home and on/off buttons at the same time
Continue holding the buttons even after the slider appears on the screen. The screen will eventually go black
When the Apple logo appears, let go of the buttons and let the iPad start up like normal.
If this works then try again through iTunes.
Apple's helpline is really good if you are still stuck.
Stephen
Post #685524 10th Feb 2018 1:56pm
Bluest
Unfortunately, it’s provided by work, so I can’t just take it somewhere to be fixed. I’ll have give it back to the IT dude, which means I probably won’t see it for 6 months. 2007 110 TDCi Station Wagon XS
Post #685575 10th Feb 2018 6:17pm
Bluest
Stephen
Can’t do the hard reset as it’s stuck mid update. 2007 110 TDCi Station Wagon XS
Post #685576 10th Feb 2018 6:19pm
mk1collector
If it's stuck mid update I'd definately do the hard reset. But then again I know nothing about computer stuff. Ray
My build thread
Post #685581 10th Feb 2018 6:34pm
VeeTee
Netherlands
You do not need any paperwork or invoices to go to an Apple Store, they know from the serial number if the device is entitled for support. You can even look that up online.
Apple’s support in the Apple Store / Genius Bar is very good! Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #685586 10th Feb 2018 6:44pm
