![]() | Home > Off Topic > Calling Apple iOS Wizards! |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
If you go into SETTINGS/GENERAL/SOFTWARE UPDATE . it will immediately check the status and then give you a current status of your software version you are using (eg your software is up to date or some other message which may indicate why it is failing to update to 11.2.5) Defender 90XS SW
Have you switched on the toggle switch entitled iTunes & AppStore? See SETTINGS/GENERAL/TOUCH ID & PASSCODE. You will then have to enter your 4 or 6 digit passcode and then check that the toggle is switched on. Also check that you have turned on the passcode. Defender 90XS SW
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Is this the only Apple device you have. If you have a MacBook or iMac, then the download is best done through iTunes . Plug the Mini in using the supplied connector using USB. The Mini should appear as a device in iTunes.
If this is your only Apple then I think you need to set up anApple ID and use that to access the app store. Downloads, even free ones cannot be accessed without an account or Apple ID. You also should have free telephone support from Apple for the first 90 days. Hope this is of some help. Stephen |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
It just says that an update is available (11.2.2) and do I want to download and install. If you choose to go ahead, the problem described above occurs. 2007 110 TDCi Station Wagon XS Last edited by Bluest on 10th Feb 2018 12:41pm. Edited 1 time in total |
Interesting, just tried this, the iPad freezes when I enter the passcode. I then have to double click the home button and quit settings to get out of it. Can't get far enough the see what the settings are. 2007 110 TDCi Station Wagon XS |
I've got an Mac Mini. Will try this now. 2007 110 TDCi Station Wagon XS |
Not good news. Tried the update through iTunes connected to my Mac. Got two thirds of the way through. iTunes then flagged error with the iPad and said the update couldn't complete.
iPad is now stuck like this... ![]() Click image to enlarge 2007 110 TDCi Station Wagon XS |
The iPad 4 Retina has updates discontinued.
Are sure this is not the case? _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I think, as Stephen suggested, as the iPad Mini is brand new, I would now ring Apple Support or if you are near an Apple store take it in to them. I've only had to use Apple telephone support twice and they were excellent both times. Good luck. Defender 90XS SW
Unplug and try a hard reset.
To perform a hard reset: Hold down the home and on/off buttons at the same time Continue holding the buttons even after the slider appears on the screen. The screen will eventually go black When the Apple logo appears, let go of the buttons and let the iPad start up like normal. If this works then try again through iTunes. Apple's helpline is really good if you are still stuck. Stephen |
Unfortunately, it’s provided by work, so I can’t just take it somewhere to be fixed. I’ll have give it back to the IT dude, which means I probably won’t see it for 6 months. 2007 110 TDCi Station Wagon XS |
Can’t do the hard reset as it’s stuck mid update. 2007 110 TDCi Station Wagon XS |
If it's stuck mid update I'd definately do the hard reset. But then again I know nothing about computer stuff. Ray
You do not need any paperwork or invoices to go to an Apple Store, they know from the serial number if the device is entitled for support. You can even look that up online. Apple’s support in the Apple Store / Genius Bar is very good! Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
