Home > For Sale & Wanted > [SOLD] Defender 110 TD5 USW (2001)
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Land Rover Defender 110 USW TD5 2001
There may not be a comprehensive service history to this vehicle, however it’s previous owners are testimony to the type of extra ordinary vehicle she is. She originally started life as one of the first centre dash TD5 Defenders and was owned by Land Rover for four years. After this ownership transferred to Bowler where she did two tours of duty as a support vehicle on the Dakar Rally. The third owner was Bell Auto Services before coming into my ownership in 2013. since then she has been serviced using OME parts and pampered to say the least. With servicing, modifications and repairs carried out by HR Auto Specialists in Co Durham.
A bit of history she was a LR vehicle and has a travel book listing the times she was driven and what she did over a few years – this also lists what work was done and needed as there is an entry each time she was taken out. From then in about 2006 she was supplied to a company that worked closely with LR and used as a support vehicle for 2 Dakar events. Obviously she was specked up for this; including an internal Protection & Performance cage, second fuel tank (now removed but the filler is still there) and various bits of electrical devices fitted such as a Terratrip 303 Plus which is still fitted.
After the second outing to the Dakar she has had little use and stood for a couple of years in a dry barn and was purchased in January 2009 with 67,702 miles on the clock (mileage taken from the MOT). Since then she saw very little use having covered some 9,000 miles since Jan 2009 but serviced and maintained to a very high standard. There is however no service history with this vehicle other than the known history and travel book.
In my ownership (April 2013) I have used her as a guide vehicle for All Terrain Tours on the Relaxed and Scenic brand of tours and since leaving ATT I have set up my own tour company. Other than odd outing to Wales and the Lake District for something a bit more challenging, she has been ultra-reliable on and off the tarmac and does what has been asked without hesitation or fuss. I converted her from a CSW to a USW more for security reasons than anything else. The rear section has internal foam and panels with a number of glove nets. I have adapted her for the tours I run so is a great vehicle as a greenlaner or overlander, best of both worlds really. I can supply the dealer direct specification sheet.
However, she is getting on for her 17th birthday and is no prom queen or virgin, so don’t expect a showroom condition vehicle, she is full of character and spirit. Full file of receipts and documentations etc included within my ownership and 2 sets of keys.
So now for the list of modifications:
BAS remapped with the boost box
EGR removal kit and de-cat pipe on
Manifold webbing cut out and upgraded extended manifold studs
Protection & Performance Full 8 point Internal Roll Cage
NANOCOM fault code reader
Ashcroft Discovery Transfer Box (fitted 2014)
Front Diff 4 pin so stronger
Detroit Truetrac Read Diff (Standard ABS & Traction Control)
Parrott hands free kit
Land Rover Alarm & Immobiliser System
6 x Boost Alloy Wheels with Cooper STT (tyres fitted Dec 2016) 2 spares are brand new
Twin rear shocks with Terra Firma shocks fitted all round, Terra Firma big bore shocks to the front
Sonic/Alisport Swing Away Wheel carrier adapted to take a High Lift Jack (inc)
Terra Trip 303 Rally Computer
Full led lights interior and exterior
Heated front windscreen
Landreiziger Electronic Fan Controls
Defender demister vents
Twin electric radiator fans linked to an X-Eng thermostatic switch (original fan supplied)
Rear 12v supply panel with permanent live, on/off switch live and ignition live with volt and amp display
Led Trucklite head lights, with position markers that come on with the side lights
4 x 3 Way Hella Spotlights (High & Low Beam) Off, Independent or with Light Switch fitted to the roof rack.
Rear Scene Light
Small led light bar front
Rear led work light
Twin led rear fog lights
High level led stop, tail and indicators
Blackvue camera front & rear
Tubular Front Bumper re worked to take a Goodwinch 9.5k with dyneema rope.
OEM Checker Plate 3mm Black, wing tops, bonnet and rear.
KBX wing top grills
Heated XS Seats (front)
Heated XS High Back Exmoor Trim rear seats (not wired up)
Tuff Trek rear door organiser
Mantec Raised Air Intake
Rock / Tree Sliders Substantial with high lift mount points
Steering Guard
Front and Rear HD Diff Guards
Flatdog roof rack and ladder
High level axle and gearbox breathers
Mudstuff sliding under cubby box housing fuses for heated seats with usb & 12v points.
FCX din cubby box with President Johnson2 CB fitted and switch panel with Carling switches for heated seats and winch control (in/out – on the to do list)
A number of usb and 12v charging points front middle and rear.
X-Eng Hand Brake (original will also be provided)
Hand Brake Modification (Range Rover hand brake) will provide the original if I can find it
Clutch spring modification
X-Eng Gear Stick Lock
How much for this highly spec’d piece of Land Rover history I hear you ask, well it can be yours for SOLD
Reason for the sale; I am looking to purchase a newer vehicle although I am in no real rush to do so.
Happy to chat about the ole girl, send me a PM and I can give you a call or supply my contact details. Adventure isn't paved!
Post #669855 9th Dec 2017 2:38pm
g-mack
£12400k Shocked Shocked bargain of the century!!!! Ive seen this in the flesh and can vouch for how good it is!!
good luck with the sale George, Can't wait to see what you do to the next one!! My 109 thread
my youtube channel
Post #669858 9th Dec 2017 2:59pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Now that's a real Land Rover and a great buy....
Post #669859 9th Dec 2017 3:21pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Be sorry to see it go George Sad Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #670147 10th Dec 2017 8:23pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
What you looking to buy next George, still have my D2 V8 that I might sell with 36k on the clock (genuine) and no rust to be seen Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #670222 11th Dec 2017 10:15am
williamthedog
That is a really nice defender, if I was in the market for one I'd bite your hand off. GLWTS Thumbs Up Thumbs Up Thumbs Up
Post #670224 11th Dec 2017 11:07am
GSLRO
Russell looking for something for more long haul tours so perhaps your V8 is a bit too, well you know what I mean. No doubt the D2 will be reliable and quipped as the 110, good luck with selling.
Once again thanks for all the kind words Bow down Bow down Bow down Adventure isn't paved!
Post #670265 11th Dec 2017 1:49pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Only £12.5K!! Shocked
.... Want swap it for a wee 90! Wink Laughing
Amazing spec! Good Luck with the sale... not that you will need it! Thumbs Up Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #670272 11th Dec 2017 2:02pm
AJC
Awesome looking 110
Post #670296 11th Dec 2017 4:00pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I'm really tempted... Tomcat or this... Confused 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #670311 11th Dec 2017 5:39pm
GSLRO
This This This
Rolling with laughter Rolling with laughter Rolling with laughter
Well I would say that wouldn't I Thumbs Up
Look at the pedigree ... ...
The original Bowler 110 Whistle Adventure isn't paved!
Post #670313 11th Dec 2017 5:42pm
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
What you getting
Post #670461 12th Dec 2017 10:32am
GSLRO
A 4x4 😂 Adventure isn't paved!
Post #670479 12th Dec 2017 12:17pm
dioliahary
Great looking vehicle, wish i had the cash. Fits my bill lovely GLWTS
Post #670480 12th Dec 2017 12:30pm
familymad
Sounds nice ! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #670491 12th Dec 2017 12:57pm
