![]() | Home > In Car Electronics > Weatherproof 12v Plugs and Sockets |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
ITT Cannon Trident connectors. Not cheap though!
Steve 02' 110 TD5 Double Cab Rebuild Thread |
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575
I’m looking for something similar, I took the cable out, via a marine cable gland in the rear panel, for my solar panel and used an amp seal connector to the panel. However I think these are a bit insubstantial and a pig to wire so I too am looking for a quality, in line connector.
For your application, suggest you look at DriPlug marine connectors, there are quite a few different types, up to 8 way, and a decent current rating as well. http://www.ecs-marine-equipment.co.uk/mari...23520.html Chris 2010 Defender 110 Station Wagon, Santorini Black. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
| smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233
Try https://www.12voltplanet.co.uk and if you type in the code "nldec17" you may get a 10% discount
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
I'd probably use XLR4 or (Mis)use a powercon or speakon connector from neutrik.
| rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945
That’s a great response. I’ll check out all those suggestions when I get home from work. Thank you everyone.
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
The Bulgin Buccaneer range of connectors are my recommendation, see my post here -
http://www.defender2.net/forum/post449301.html#449301 Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052
And mine! Good value too.
| All times are GMT |
