![]() | Home > In Car Electronics > Pioneer releasing the first single-DIN unit with Carplay |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 395 ![]() ![]() ![]() |
You will need to buy an ISO adapter. Got mine from MUD. Then it plugs in all ok and the sub is all part of that connection
scotiasteve Member Since: 13 Sep 2015 Location: Edinburgh Posts: 28 ![]() ![]() ![]() |
Thanks mate, that is me sold... |
MudHugger Member Since: 17 Jan 2016 Location: Essex Posts: 28 ![]() ![]() ![]() |
I’m tempted. I have a phone microphone on my steering column connected to the alpine unit which came with my Defender from new.. Does it work with that?
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
I’m sure the alpine uses the same mini phono jack for the microphone so I’d say yes, but even if not just use the pioneer mic it’s not difficult to fit that bit My 90 Project : http://www.defender2.net/forum/topic52774.html
A few weeks in and I must say the only thing I’m disappointed about this pioneer is I didn’t get it sooner; it’s fantastic .
I also like the button which temporarily folds the screen flat to allow access to the buttons which it blocks - it’s like they designed it for the Puma dash! My 90 Project : http://www.defender2.net/forum/topic52774.html |
The standard mic does not fit the pioneer head unit. I just fitted the supplied mic next to the standard one and ran the wire
across. Very simple. I also have spent hours designing and making extension looms in order to re locate the hidden switches into a mud pod on top of the dash. Haven’t done it yet and I have found that the screen easily flips down if Required. I am still thinking about this. Probably will re locate the switches in due course and also convert the hazzard switch to the discovery type. Although this is al little more involved. ![]() |
Do I need any particular connector for my 2016 puma?
Al_The_Pal Member Since: 09 Feb 2015 Location: Near the bottom on the right Posts: 146 ![]() ![]() |
Heads up, these are now down to £491 on Amazon.
Ponclair Member Since: 12 Dec 2015 Location: Surrey Posts: 22 ![]() ![]() ![]() |
Any chance of a link? I can't find this unit on Amazon (UK)
https://www.amazon.co.uk/gp/offer-listing/B0757K5HKP
Hopefully that works |
Heads up, Amazon are doing the newer version of this for £349 at the moment... search for “CarPlay single din” it’s the Pioneer Z710
gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 126 ![]() ![]() |
..... and Argos. Cheers
Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
Now £339 at Amazon... cancelled and reorder
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Hi all,
Can anyone confirm if an ISO adapter is needed to fit the Pioneer Z710 replacing the current Alpine CDE-133BT that I have? I'm interested in buying the Pioneer based on the current price on Amazon but want to make sure I know what I'm getting into! Thanks. |
