Home > Puma (Tdci) > roll cage please
treps
roll cage please
I am at a decision point. Sell my 110 Adventure or increase its safety features. Using it in the mountains, etc, I am concerned about rolling. So I am looking at safety cages. Does anyone have experience with the Safety Devices L172? The 8pts full cage.
(http://www.safetydevices.com/expedition/products/roll-cage/Land+Rover+Defender+110+Puma-2007-2015-5-door-Station+Wagon/290/1937/)
I am new at this... Does it really fix to the chassis providing enough structural strength to the cabin? Or is the protection area only the 'cage volume'? Other advice or options most welcome. Many thanks.
Post #657885 17th Oct 2017 3:57pm
bankz5152
That cage bolts to the chassis in 3 points. The front, middle and rear, thats also a very comprehensive cage being internal and external. Very solid indeed, if you are not confident in doing it yourself you'll have to get some one to fit it which is usually the cost of the cage +20% (based on previous quotes I have gotten)
Post #657886 17th Oct 2017 4:02pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
A proper cage will provide a lot of protection if fixed to the chassis.
This is a picture of a rolled 90 with an internal/external frame over the front only.
The frame also links under the chassis to create a complete loop of strength
Note how both wings and the roof are damaged so it must have rolled but cabin space is intact
This is the cage I have now fitted to mine - SD L138/7
Post #657968 17th Oct 2017 8:44pm
xcentric
I have a Safety Devices cage in mine - external at the front, internal at the rear. It bolts to the cross members and is very strong, and means I'm happier in the wilds with family on board. But it was in the vehicle from new - I've not put one in. If you're keeping your land rover, then it's a good investment. But they don't come up second hand often as people either keep them in, or can't be bothered to fit them - so little supply or demand.
Post #657985 17th Oct 2017 9:52pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I like that, can you use a raised air intake with one of these?
It mentions "Will fit bulkhead models, although bulkhead will need to be trimmed." what needs trimming? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #657987 17th Oct 2017 9:54pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Have you got any photos if the inside by any chance?
I've read the fitting instructions but they are a bit light on photos.
Does it replace the standard bulkhead removal bar or fitted as well?
Where do the rear supports run? The fitting instructions mention they aren't connected to the hoop?
Post #658005 17th Oct 2017 10:55pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I got that cage on my 110 2010 and it comes with an internal hoop, right behind your seats. The bulkhead comments are only for 90's and I even got the LR OE cargo barrier fitted. You can do it by yourself but count 2 to 4 days unless you want to rushed. I also added Dynamat at the same time as the interior has to come out. m
Post #658012 18th Oct 2017 1:51am
boode
Yes
Post #658089 18th Oct 2017 12:47pm
boode
I will take some photos of the inside
The bulkhead is replaced with a new bar that is part of the cage - also has a bar under the chassis to further strengthen the structure
I did not install the rear supports - I think they were to give a fixing for rear seat belts but I have no rear seats
Post #658091 18th Oct 2017 12:55pm
boode
Internal shot of cage
The pillars that go down the sides Bolt to another bar that runs under the bodywork and also bolts to the chassis
The front hoop extends down through the wings and onto the chassis
Post #658102 18th Oct 2017 1:36pm
treps
Thank you for the replies, very helpful.
I am OK with the external cage look so it looks as if I�ll go with SD�s L172. Trek Overland were helpful when I called them. However, ideally they want the car for two weeks. Timing and logistics are the next challenge. Thanks again.
Post #658104 18th Oct 2017 1:57pm
Kit
That cage looks really nice on a 110, I think you'll be very happy Thumbs Up
Here's an alternative: http://www.whitbread-offroad.co.uk/roll_ca...php#switch 1993 200 Tdi 90 CSW
Post #658116 18th Oct 2017 2:48pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
boode wrote:
Yes
What make is it, how much are they.
Post #658146 18th Oct 2017 5:17pm
boode
Its a Safety Devices L138/7 - designed for the 50th model - don't know cost of them now
Post #658149 18th Oct 2017 5:37pm
V8GPC
Post #658172 18th Oct 2017 6:52pm
