![]() | Home > Puma (Tdci) > roll cage please |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
That cage bolts to the chassis in 3 points. The front, middle and rear, thats also a very comprehensive cage being internal and external. Very solid indeed, if you are not confident in doing it yourself you'll have to get some one to fit it which is usually the cost of the cage +20% (based on previous quotes I have gotten)
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
A proper cage will provide a lot of protection if fixed to the chassis.
This is a picture of a rolled 90 with an internal/external frame over the front only. The frame also links under the chassis to create a complete loop of strength Note how both wings and the roof are damaged so it must have rolled but cabin space is intact This is the cage I have now fitted to mine - SD L138/7 ![]() |
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 ![]() |
I have a Safety Devices cage in mine - external at the front, internal at the rear. It bolts to the cross members and is very strong, and means I'm happier in the wilds with family on board. But it was in the vehicle from new - I've not put one in. If you're keeping your land rover, then it's a good investment. But they don't come up second hand often as people either keep them in, or can't be bothered to fit them - so little supply or demand.
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I like that, can you use a raised air intake with one of these? It mentions "Will fit bulkhead models, although bulkhead will need to be trimmed." what needs trimming? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
Have you got any photos if the inside by any chance? I've read the fitting instructions but they are a bit light on photos. Does it replace the standard bulkhead removal bar or fitted as well? Where do the rear supports run? The fitting instructions mention they aren't connected to the hoop? |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
I got that cage on my 110 2010 and it comes with an internal hoop, right behind your seats. The bulkhead comments are only for 90's and I even got the LR OE cargo barrier fitted. You can do it by yourself but count 2 to 4 days unless you want to rushed. I also added Dynamat at the same time as the interior has to come out. m
Yes ![]() Click image to enlarge |
I will take some photos of the inside The bulkhead is replaced with a new bar that is part of the cage - also has a bar under the chassis to further strengthen the structure I did not install the rear supports - I think they were to give a fixing for rear seat belts but I have no rear seats |
Internal shot of cage
![]() Click image to enlarge The pillars that go down the sides Bolt to another bar that runs under the bodywork and also bolts to the chassis ![]() Click image to enlarge ![]() Click image to enlarge The front hoop extends down through the wings and onto the chassis |
treps Member Since: 07 Jul 2015 Location: SE Posts: 244 ![]() |
Thank you for the replies, very helpful.
I am OK with the external cage look so it looks as if I’ll go with SD’s L172. Trek Overland were helpful when I called them. However, ideally they want the car for two weeks. Timing and logistics are the next challenge. Thanks again. |
That cage looks really nice on a 110, I think you'll be very happy
![]() Here's an alternative: http://www.whitbread-offroad.co.uk/roll_ca...php#switch 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
What make is it, how much are they. |
Its a Safety Devices L138/7 - designed for the 50th model - don't know cost of them now
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
http://www.paddockspares.com/roll-cage-1.html
£1,076.30 Fitting Instructions http://www.safetydevices.com/uploads/rollcage/276.pdf |
