![]() | Home > Technical > Main fuse box under driver's seat same on TD5 and 2.4 Puma? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello stanlee
Correct...'well' my friends 2007 TD5 has the same Fuse Box as my Puma 2.4. 2.4 Puma... ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
stanlee Member Since: 29 Jul 2014 Location: Stirling Posts: 5 ![]() ![]() ![]() |
Fantastic - thank you so much for the quick response.
Your welcome...
![]() May also be of use... Puma... ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
^^ I'm glad my diagram is still proving useful.
Hello balckwolf
Indeed... ![]() ![]() ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
Not immediately to hand. The original diagram you may recall was titled "Puma Relays" and page 2 listed the relays under the dash.
If it would be useful I will update it to cover the relays and fuses for the 2.4 in both locations. |
Thanks blackwolf, if it's not too much bother, that would certainly be useful.
