Bad experience which started yesterday. Without much preadvise on way home from work gear change started to become difficult, and in a matter of 2 km no more gear selection possible with engine running, so verdict, clutch kaput at 89.000KM. Actually lucky that it happened just outside town yesterday, better than somewhere halfway between Geneva and Entreq in Germany where we were supposed to be heading this morning. That trip and the works there will need to be rescheduled to later this fall.
Within half an hour of calling them, I was towed to temporary safety by our TCS (see pic) as this weekend we have a the visit of www.royal-de-luxe.com with their giant puppets which is drawing 1 million visitors and a total stop of all traffic in and around town. So truck has stayed overnight in that spot, then was winched onto a flatbed truck this morning at 07.00 hrs at which time it still was possible to transit town to drop it at our JLR dealer. Will surely be a new clutch next week, but will decide with dealer what all to change after they open up the truck next week. Guess also a chance to look at the condition of the engine to gearbox shaft. Or, as my friend Olaf from Entreq Whatsapp'd me, "Die Zwischenwelle Getriebe/Verteilergetriebe unbedingt kontrollieren lassen!!!" Ja, selbstverstndlich doch, Olaf. ![]() Eric ![]() Click image to enlarge Now that I come think of it, second time on one month that the truck goes on a flatbed. Beginning September also on the french payage after a hose came loose. We should start a thread with Defenders on tow trucks/flatbed trucks. ![]() ![]() ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 30th Sep 2017 5:25pm. Edited 1 time in total |
Gutch1985 Member Since: 15 Dec 2015 Location: Yorkshire Posts: 105 ![]() ![]() |
Gave it a bit of a wash an made some plans for it over winter
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
^^^ Very nice
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
Used the old girl to drag the trailer full of branches after doing some clearance work at my works yard. Then went home and fit door silk trims
![]() Click image to enlarge ![]() Click image to enlarge |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
another thread regards drive flange spline rust made me think that I have never checked my front drive flanges, so whipped off the wheels, drivers side rubber cap had a very very small amount of rust powder in it, removed the drive member bolts and cir-clip pulled off the flange and all was good nice snug fit but was dry with evidence of rust starting to form, passenger side was all like new, reassembled both sides with copious amounts of corrosion block grease. All in took 2 hrs but that included some time searching for flange gaskets and the thread lock I knew I had somewhere but couldn't find when I needed DEFENDER 90 TDCI XS,
Cactus79 Member Since: 09 Jan 2017 Location: Cheshire Posts: 51 ![]() ![]() |
Swore lots at the previous owner for .... maintenance.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Jacked the front of mine up on stands ready for some minor work tomorrow.
What lovely weather we have as usual. ![]() Maybe it'll dry out by tomorrow who knows otherwise it'll be lying on the ground in the wet probably on soggy cardboard before I know it. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Removed the cubby box and "under cubby box" with all the additional electrics, relays, etc. in order to prepare for the installation of a new upgrade:
a Roamerdrive. ![]() ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
Got round to fitting bits I acquired at Peterborough.
Mantec RAI to replace my rusty metal one, nice straight forward fit. Land Rover/Mantec spare wheel carrier curtesy of Duckworths. Carrier was easy enough to fit, however getting the boost alloy to fit correctly wasnt. Phone call to Duckworths who sent me out the extensions needed for alloy wheels FOC. Fitted the extensions but then they stuck to far out meaning couldnt tighten up the wheel for ![]() Another phone call to Duckworths & I was told had the same problem before. The way round it was to take off the large round threaded washer from my old wheel carrier & set them up at the correct depth on the extensions. This I did and it now all fit & works as it should ![]() Lastly put on some new rear mud flaps, just cut the old bolts off & used new bolts & washers. Also recently had new gearbox, clutch, flywheel & all bits to go with it Got the transfer box on order for fitting next Tuesday. Hopefully thats enough spent on her for now. Heres to another 230,000 miles ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261 ![]() ![]() ![]() |
Looks good Martin
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Hit a small milestone today,
![]() Click image to enlarge 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Jacked up all four corners one at a time, took wheels off.
Checked brakes, checked tyre's and picked all the grit out and stones. Little point but isn't the best rubbish to have between treads. All good thank goodness, was just due a check and that is enough for one day. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
You will be doing it all again following next Saturday!
![]() ![]() Brakes were my main interest. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
