Home > In Car Electronics > 5.25" speaker upgrade
Djcla
Wondering if you can fit 5.25" speakers under the dash in a td5 90 to replace the standard ones with limited hassle? Anyone done this anything I need to watch for cut out hole size etc?
Post #648339 4th Sep 2017 11:04pm
barbel jim
Yes fitted Focal K2 power in both a puma and td5 no adapters necessary. Passenger side requires a bit of tapping with a hammer to sit flush, other than that relatively simple Thumbs Up
Old photos showing focal shallow mount KRS, but been upgraded since to K2 powers Mr. Green
Post #648370 5th Sep 2017 8:12am
Djcla
Did you have to cut bigger holes? Those speakers are pricey the Pioneers I found look to have a mounting depth of about 46mm
http://caraudiosecurity.com/ts-g1333i-3-way-coaxial-speakers-250w
Post #648534 5th Sep 2017 10:11pm
barbel jim
They are Whistle but it all depends what you want ?
Yes you have to enlarge the holes slightly, but its relatively simple. IMO you wont gain much swapping to those pioneers. You'd gain more buying components than coaxials. A set of genuine puma take outs will probably sound better, with the highs above the dash Thumbs Up
Post #648581 6th Sep 2017 11:24am
JOW240725
If necessary you can get spacer rings if new speakers are slightly deeper. For example http://farcorners.co.uk/product/shallow-sp...ngs-130mm/ James
Instagram @suffolk_rovers
Post #648598 6th Sep 2017 12:18pm
Djcla
how hard is it to fit some components then? ie would i need to take dash apart to hide the cross over box?
Post #648601 6th Sep 2017 12:43pm
Djcla
barbel jim wrote:
They are Whistle but it all depends what you want ?]
im not after anything pricey but what i have currently is awful but im no expert on car audio so recommendations welcome
Post #648604 6th Sep 2017 12:54pm
JOW240725
See the for sale section http://www.defender2.net/forum/topic56814.html James
Post #649980 12th Sep 2017 10:40pm
