![]() | Home > In Car Electronics > 5.25" speaker upgrade |
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1459
Yes fitted Focal K2 power in both a puma and td5 no adapters necessary. Passenger side requires a bit of tapping with a hammer to sit flush, other than that relatively simple
Click image to enlarge Click image to enlarge Click image to enlarge Old photos showing focal shallow mount KRS, but been upgraded since to K2 powers |
| Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469
Did you have to cut bigger holes? Those speakers are pricey the Pioneers I found look to have a mounting depth of about 46mm
http://caraudiosecurity.com/ts-g1333i-3-way-coaxial-speakers-250w |
They are
Yes you have to enlarge the holes slightly, but its relatively simple. IMO you wont gain much swapping to those pioneers. You'd gain more buying components than coaxials. A set of genuine puma take outs will probably sound better, with the highs above the dash Click image to enlarge |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
If necessary you can get spacer rings if new speakers are slightly deeper. For example http://farcorners.co.uk/product/shallow-sp...ngs-130mm/ James
how hard is it to fit some components then? ie would i need to take dash apart to hide the cross over box?
im not after anything pricey but what i have currently is awful but im no expert on car audio so recommendations welcome |
See the for sale section http://www.defender2.net/forum/topic56814.html James
| All times are GMT |
