![]() | Home > In Car Electronics > 5.25" speaker upgrade |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
Yes fitted Focal K2 power in both a puma and td5 no adapters necessary. Passenger side requires a bit of tapping with a hammer to sit flush, other than that relatively simple
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Old photos showing focal shallow mount KRS, but been upgraded since to K2 powers ![]() |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
Did you have to cut bigger holes? Those speakers are pricey the Pioneers I found look to have a mounting depth of about 46mm
http://caraudiosecurity.com/ts-g1333i-3-way-coaxial-speakers-250w |
They are
![]() Yes you have to enlarge the holes slightly, but its relatively simple. IMO you wont gain much swapping to those pioneers. You'd gain more buying components than coaxials. A set of genuine puma take outs will probably sound better, with the highs above the dash ![]() ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
If necessary you can get spacer rings if new speakers are slightly deeper. For example http://farcorners.co.uk/product/shallow-sp...ngs-130mm/ James
how hard is it to fit some components then? ie would i need to take dash apart to hide the cross over box?
im not after anything pricey but what i have currently is awful but im no expert on car audio so recommendations welcome |
See the for sale section http://www.defender2.net/forum/topic56814.html James
