Home > My Defender > A second 110 on the drive - 300tdi csw BMW powered!
Page 7 of 14 <123 ... 678 ... 121314>
lb73
Wales
Yes, must admit I was pleased that it's been reliable so far Very Happy
Anyway after using it daily over the last month or so, and not doing a great deal to it - I decided to make a start on the carpet that turned up from Exmoor trim at the start of August.
Before starting I double checked for leaks around the door areas as the last thing I wanted was wet carpets, all was good surprisingly. The only leak I could find was around the d/s rear slider which seems to be lose along the bottom edge and allowing water in, so this will need removing and re riveting and bonding back in place, something I'll do in the next week or so before carpeting the rear out.
I had already fitted silent coat previously so even though the carpet had a soundproofing backing I decided to fit 6mm thick dodo liner to areas that, allowed once fitted I glued the carpet in place
So far done the front bulkhead, seatbox, and side kick plates so got a long way to go.
As with most defender jobs it's been a bit more time consuming than I initially thought however the carpet fits well with only minimal trimming needed, though there is a couple of pieces that I cannot work out for the life of me where they go Laughing 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #646811 28th Aug 2017 8:34pm
L110CDL
They most probably just put them in there to confuse you Laughing
Good progress there Thumbs Up Clayton.
Keeper.
Post #646839 28th Aug 2017 10:17pm
lb73
Wales
Cheers Thumbs Up 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #647290 30th Aug 2017 10:58pm
Procta
looking great! Carpeting mine out is a long way off sadly, got a good journey to go before all that sadly. Sad Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #647432 31st Aug 2017 4:54pm
lb73
Wales
Cheers, carpeting is one of those jobs best left to last, plus it gave me enough time to save up for it - as in my case it was one of the most expensive purchases.
Anyway on the subject of carpet , I managed to get a bit more done, mainly the 2nd row seats. I started with pulling the rear seats to make the job easier
The most fiddly part was trimming around the mounting brackets of the seats , but in the end it doesn't look to bad
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #648318 4th Sep 2017 9:34pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Looks like a good job to me Thumbs Up 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #648333 4th Sep 2017 10:22pm
Procta
I thought the carpet was already trimmed up, do you have to tweak a little? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #648431 5th Sep 2017 1:08pm
lb73
Wales
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #648469 5th Sep 2017 6:19pm
L110CDL
Tidy Wink Thumbs Up Clayton.
Keeper.
Post #648684 6th Sep 2017 9:17pm
lb73
Wales
Yes in so much as round the rear puma seats mounting points bearing in mind it's a carpet set for a 300tdi, overall though it's not to bad. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #648704 6th Sep 2017 10:44pm
lb73
Wales
L110CDL wrote:
Tidy Wink Thumbs Up
Thanks 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #648706 6th Sep 2017 10:44pm
lb73
Wales
Tried fitting the decals I bought to hide the scratch on the passenger side doors. Only done near side so far but it doesn't look too bad, with most of the scratch hidden
Here's some poor quality pictures to look at
[img:870:650]https://www.defender2.net/gallery/albums/userpics/20405/normal_IMG_2359.JPG
Just need to get a black tdi sticker to replace the white ones 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #648709 6th Sep 2017 10:50pm
Profyaffle
I like those.. Thumbs Up 1993 200Tdi Defender 90
Post #648714 6th Sep 2017 10:59pm
L110CDL
That looks really good Ib73 Thumbs Up as you say, the white ones need to be black as well Wink Clayton.
Keeper.
Post #648715 6th Sep 2017 11:02pm
lb73
Wales
Cheers both, managed to do the drivers side tonight, just before it chucked it down! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #649966 12th Sep 2017 9:36pm
