![]() | Home > Maintenance & Modifications > Relay inside battery box...or better not? |
Nope. The relay for the standard Land Rover towing electrics loom is located in the battery box. Darren
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
Is that right? Mine is a LHD and I'm pretty much sure I have not seen it. Puma 110" SW
It was on the TD5 that I last installed and is on my current 200tdi. Both are RHD though, so maybe the layout is different. Darren
Ok. Anyway, some have relays inside the battery compartment.
![]() ............................................................. Earth first. Other planets later |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
No problems at all, calling the battery box sealed is optimistic at best!
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello MK
LandRoverAnorak is right, the recommended location for the LR OEM 13Pin Towing Electrics Relay is within the Battery Compartment... (this is my Puma 2.4) ![]() Click image to enlarge ![]() Click image to enlarge I would say Low or No Risk at all, if the correct Relay and Loadings are in place... (avoid any cheap 'sub-standard' electrics ![]() https://www.defender2.net/forum/topic83242.html |
The standard battery is vented via a pipe running out through the floor of the compartment (at least is it on my 2007 Defender).
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
^^^^ This is true, there is no issue at all.
Definitely use quality branded wiring and Relay though. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thanks all for the answers. Puma 110" SW
