Home > Maintenance & Modifications > Windscreen rubber replacement
AVB
United Kingdom 2003 Defender 110 2.5 TD SW Epsom Green
Mine has split so having trawled through the posts on here where people had recommended Autoglass I rang them to see what it would cost for them to replace the rubber only. The simple answer is that they wouldn't do it. They would only replace the windscreen. And the cost of that was £300. Thieving ********.
I then rang a local independent who quoted £70 for a new rubber and installation and if it needs a new windscreen it's another £32. Much better.
Post #644484 16th Aug 2017 6:18pm
Typically best to replace both in case there were any weaknesses.
Remember there are different glass types and brands with varying quality.
Genuine would not be cheap, cheap is not always good. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #644486 16th Aug 2017 6:21pm
zsd-puma
I've been led to believe the aftermarket rubber seals are too fat and you risk cracking the glass when fitting them. So make sure you get an assurance from the fitter that if they glass gets broken while refitting he'll replace the glass at his own expense.
Cheap screens can end up with optical flaws in them, they're horrible. £32 is probably a standard non tinted, non heated screen. It'll be more if yours is heated, it would be daft not to fit a tinted one even if yours wasn't originally. They take the edge off the heat on a sunny day.
Post #644489 16th Aug 2017 6:39pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Re: Windscreen rubber replacement
That sounds too cheap to me?
EDIT: Didn't realize how cheap the non-heated/non-LR windscreens are! 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #644493 16th Aug 2017 6:45pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Been quoted £50 for a genuine rubber seal Shocked πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #644495 16th Aug 2017 6:47pm
Peaknocker
United Kingdom 2014 Defender 90 Puma 2.2 HT Fuji White
That's cheap, I paid nearly £100 for the genuine windscreen rubber Big Cry Mike
Post #644497 16th Aug 2017 6:50pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Nothing wrong with Bearmach rubbers , I put mine in bucket of boiling water before fitting,
Post #644515 16th Aug 2017 8:02pm
AVB
Job Done. I went for replacement screen as there was a chip in the original that I hadn't spotted. The new screen is from Pilkington and I went for a tinted one for £38. Total fitted price with new rubber was £108. So I don't know what would have been better for Autoglass to quote £300.
Post #644724 17th Aug 2017 6:02pm
Did you do it yourself? ____\We|Will|Win/___
Post #644725 17th Aug 2017 6:03pm
AVB
You don't know me do you? No I would not attempt anything as complicated as that! The price was fitted.
Post #644726 17th Aug 2017 6:09pm
