![]() | Home > Maintenance & Modifications > Windscreen rubber replacement |
Typically best to replace both in case there were any weaknesses.
Remember there are different glass types and brands with varying quality. Genuine would not be cheap, cheap is not always good. _\Hennessey|Venom| F5/___ ___\βοΈLone|Star|State/___ ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I've been led to believe the aftermarket rubber seals are too fat and you risk cracking the glass when fitting them. So make sure you get an assurance from the fitter that if they glass gets broken while refitting he'll replace the glass at his own expense.
Cheap screens can end up with optical flaws in them, they're horrible. £32 is probably a standard non tinted, non heated screen. It'll be more if yours is heated, it would be daft not to fit a tinted one even if yours wasn't originally. They take the edge off the heat on a sunny day. |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
That sounds too cheap to me? EDIT: Didn't realize how cheap the non-heated/non-LR windscreens are! 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top Last edited by Kit on 16th Aug 2017 6:49pm. Edited 1 time in total |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 ![]() ![]() ![]() |
Been quoted £50 for a genuine rubber seal
Peaknocker Member Since: 14 Apr 2017 Location: North Yorkshire Posts: 138 ![]() ![]() ![]() |
That's cheap, I paid nearly £100 for the genuine windscreen rubber
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Nothing wrong with Bearmach rubbers , I put mine in bucket of boiling water before fitting,
AVB Member Since: 04 Jul 2016 Location: Herts Posts: 15 ![]() ![]() ![]() |
Job Done. I went for replacement screen as there was a chip in the original that I hadn't spotted. The new screen is from Pilkington and I went for a tinted one for £38. Total fitted price with new rubber was £108. So I don't know what would have been better for Autoglass to quote £300.
Did you do it yourself? _\Hennessey|Venom| F5/___
You don't know me do you? No I would not attempt anything as complicated as that! The price was fitted.
