![]() | Home > Maintenance & Modifications > Clear Indicator lenses |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
I've used these:-
http://tinyurl.com/66o9lph Last edited by WelshGas on 19th Mar 2011 7:58pm. Edited 2 times in total |
link don't work
![]() found the lights are they bright and do you need to get the resister with them ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
I haven't got the resistor. There is no bulb warning system for the side/tail/braking lights on the Defender to my knowledge so no need for the resistor.
They are brights. There are other bulbs on ebay with upto 25 LED's per cluster. |
Cheers mate the reason i asked is i got some from ebay and they was
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I put led clusters in them that I got off eBay. Youre right, if you put those conventional bulbs you can get which have been painted red, they make the light look a bit pink. I didn't like them either so went for led's. Pete |
Pete are they the leds in your link you put in the stop and tail ?
these http://cgi.ebay.co.uk/1x-RED-13-LED-BA15S-...519805d0a2 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
No the led in that link was for the fog lamp. The stop tail ones I bought are here:
http://cgi.ebay.co.uk/Land-Rover-Land-rove...3727wt_922 |
Cheers Pete, Ordered
![]() Last edited by fekete on 20th Mar 2011 1:14pm. Edited 1 time in total |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Where's the best place to get the clear lenses from? Do you have to buy replacement units, or can you just change the lens? I read somewhere that the lenses on later vehicles are sealed to the lamp holder, so you have to change the whole unit. I ordered clear / smoked side repeater lenses yesterday, but found loads of different suppliers of front / rear clear units with quite a large variety of prices. Foundry 4x4 seemed to be one of the cheapest. Any advice appreciated. Cheers.
Just buy the lenses you don't need the units...i got mine from bolt on bits as a package but the units they supply are not the best, ended up using my old units
If youve got a Puma the lens cannot be separated from the back plate piece. Only the bulb holder can be removed. I got a pair of Wipac rear lamps from www.offroadrovers.co.uk for about £10 plus postage. They have a shop on eBay too.
Pete |
Sorry Green Machine thats what i meant bulb holders .
No worries - thanks for the advice. I'll have a look at the offroad rovers site - probably get them from there. Cheers.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20962 ![]() ![]() |
Any link available for the LED brake lights at all?
Cheers |
