Home > Maintenance & Modifications > BAS Remap evolution (NO EGR) upgrade
Page 2 of 2 <12
jst
slightly OT but are you meant to wait for EGT to drop below 160C prior to turning off? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #64008 16th Mar 2011 10:39pm
Naks
One should always idle a turbodiesel before switching off. I always wait until the EGT falls to 160C, although anything below 200C should be fine. --
Post #64029 17th Mar 2011 5:48am
jst
i know you should always idle it, just wasnt aware of the 160figure, where does that come about then? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #64032 17th Mar 2011 7:29am
Naks
Whistle --
Post #64034 17th Mar 2011 8:09am
Naks
Re: BAS Remap evolution (NO EGR) upgrade
dgardel wrote:
EGR is ALWAYS CLOSED, it stay at 16-18% ONLY AT IDLE, but when I "touch" the throttle it go to 0% always.
Daniele, forgot to ask - how do you know this? --
Post #64057 17th Mar 2011 10:47am
dgardel
Italy
When I test maps for Pete, I'll drive with the Nanocom Evolution connected in OBD dashboard mode where I can read the parameters that I want to check (EGR, common rail pressure, turbo pressure, water temp, inlet air temp, engine charge,....) and record its on file. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #64066 17th Mar 2011 12:32pm
Naks
dgardel wrote:
When I test maps for Pete, I'll drive with the Nanocom Evolution connected..
Ah, nice, thanks Thumbs Up --
Post #64069 17th Mar 2011 12:42pm
MK
Daniel
what are the measurement UNITS displayed by the NNCOM? SI?
ciao
MK Puma 110" SW
Post #64077 17th Mar 2011 2:36pm
dgardel
Italy
Yes metric system..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #64081 17th Mar 2011 3:34pm
jst
Naks wrote:
Whistle
Sorry i am obviously not privi to this information and your knowledge exceeds mine on this topic, hence why i asked. i didnt realise i had to whistle for it.
sometimes i really wonder about this forum. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #64141 17th Mar 2011 9:22pm
Naks
jst wrote:
Sorry i am obviously not privi to this information and your knowledge exceeds mine on this topic, hence why i asked. i didnt realise i had to whistle for it. sometimes i really wonder about this forum.
James, sorry boet, no offence/malice intended. The 160C is a thumbsuck of mine - by all accounts anything around 200C should be ok.
After the BAS remap with EGR-shut, initial fill up after a 200km run returned consumption of 9.5l/100km.
Went to Tulbagh for the long weekend and gave it some foot on the R44 in strong winds, and spent an hour idling in heavy traffic on Boyes Drive this evening. Consumption was 10.8l/100km after this run.
Will continue to monitor & report consumption. --
Post #64620 21st Mar 2011 9:32pm
Naks
Daily commute to & from work, on BAS 1.7.2 running on BP 50ppm, consumption was 9.6l/100km. --
Post #65931 1st Apr 2011 8:51pm
Page 2 of 2 <12
