![]() | Home > My Defender > Proctas Defender 300TDI |
Yeah, it can. I swapped the hinges on my drivers door a few months ago for exactly the same reason and did it one at a time. If you're going to buy new bolts, make sure to get matching captive nuts as the originals are Imperial. I sheared off two of the originals before realising my mistake ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5374 ![]() ![]() |
Cheers LRA for the heads up, I can see mine been a pain to get out anyway. So I will just by the full blown kit before I go anywhere near! Less head aches the better! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
well today I made a start on sorting out the exhaust system, I slackened off my down pipe from the manifold, and I will have to cut the two nuts and off where it meets the centre section.
Also I managed to repair a snapped bolt in the rad bracket, I needed up winding off the welded nut, so shoved a nice nut and bolt through. So another little job done ![]() Going to order off some service items, I think. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
What are you doing with your exhaust? staying standard, upgrading or repairing? 1993 200Tdi Defender 90
Haha Profyaffle, you got in there before I got the chance to do a thread update
![]() ![]() Exhaust, Right another item that's bugged me, Is the CAT! Why the hell do they shove these on Diesels is beyond me! My 306 HDI had one on and it got binned, best upgrade I ever did to the car. Made such a difference in turbo spool and lower end power. So I have now done the same thing to TDI, ![]() Anyway I pulled the pipe off ![]() Click image to enlarge it has seen better days has it not! ![]() Click image to enlarge the replacement unit ![]() Click image to enlarge All bolted in place and I started the engine just to check if there was any blows or rattles. ![]() Click image to enlarge Everything is spot on! While things were moving one great, I thought why not replace the quarter supports with the galvanised quarter supports that I had won on ebay and got painted at work. Mind my old ones were rotten! ![]() Click image to enlarge the passenger side one had been repaired! ![]() Click image to enlarge Replaced them with these ![]() Click image to enlarge on the car with new nuts and bolts ![]() Click image to enlarge ![]() Click image to enlarge So all is good ![]() I took her out for a quick test, and I tell you something, its about 10 to 15% faster! She picks up in her gears better than before! due to the fact she can rev better now, and she is a little quicker off the mark too, and picks up a lot better in second gear too. She was well sluggish in 1st and 2nd gear, when I got her. But I think its been to do with the EGR system, also since I have put in an ITG filter and the last upgrade ( DECAT) She really is now on the money! Pokey as my dads 200 TDI ( known to me as our Terr) I am researching brakes upgrade as I do have a imbalance, also I am looking at another cosmetic change too at the front. its nice to start moving on with things now ![]() I have to adjust the tappets though as she is very tappy when on the move. I will have to do some reading on that, as that scares me ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Great work.. It's good that you've noticed an increase in performance.. makes it all worthwhile
going to do a oil and filter change too at some point this week, when I buy the oil. So that I can tick that off the list.
Also I will push forwards for my brake upgrade after confirming with L110CDL on what he ran. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Good work matey
![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Your tappet noise, where do you fill up with diesel for your landy ? Clayton.
I fill up at my local shell, now and again i use BP. I will not shove supermarket
![]() ![]() Could that be something to do with the fuel? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
well today I had to back off with facelift/ upgrade before it went any further. I am going to need some replacement parts by the looks of things, before I go anywhere near the lights!
Anyway after been worried about how to go about servicing the defender, I just took it at a stage at a time, i know its daft. but i haven't changed a fuel filter on a mech pump diesel. The oil change is simple enough though, but by Christ it must have needed it! The oil that was in it had seen better days, fuel filter was clean enough so no worries about any dodgy ![]() So i have nice moble 2000 15w 40 in now and the engine is quiet as my hdi practically now! Nice and smooth idle too and no where near as clattery as it was before. So it could have been the old oil making her tap? we will see when i take her out, She was a little clattery when i started her up just to make sure all is well, ran her for a little bit, then powered off and checked and topped up. started her up and little her run for a while and she is well smooth now on tickover. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
My dad took her out last night for a quick test, and we did confirm that the tappets need a little tweak. like I say I don't know when these were last looked at either and she has got 120k on her clock now.
He said she is lively and pulling well now since we 1st got her, So we are going in the right direction! ![]() Just the little things that make the difference isn't it ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
You certainly are Procta going in the right direction
![]() ![]() ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I think I will get my work mate to help me, with the tappets I don't think my dads to sure or too keen on the idea. He thinks its something else now lol.
I have my brake upgrade and service items on order! ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
