Home > Technical > strange thing...AGAIN!
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
...happened to me this afternoon ...
I got in to the car, When I turned the key , the roof light turned off and then on, and when I turned the ignition on, the trip meter on the speedometer had been reset to zero, and the presets on my radio were gone ...
Any ideas ? Could this be the beggining of troubles ?
The only extras wired on my Defender are the radio, the winch (straight to the battery) and the trailer electrics (that I smashed yesterday agains a hydrant) Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #63468 12th Mar 2011 9:33pm
110SEB
Is this down to part No. LR459801? The LRG (Land Rover Ghost)?
Sorry I'm being useless Thumbs Up
Post #63477 12th Mar 2011 10:46pm
110SEB
Post #63478 12th Mar 2011 10:47pm
AndrewS
Re: strange thing...
Wellllll at a guessssss Whistle Whistle
I would disconnect (pull the plug out) the trailer wiring harness before you cause any more issues Thumbs Up 130's have feeling's as well you know Smile
Post #63500 13th Mar 2011 10:25am
lrmaniac
could be that the resason? the feeling I got was that the conection to the battery had been interrupted for a second ... and caused that reset of the tripmeter and the radio ... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #63530 13th Mar 2011 1:52pm
MK
The main earth plug of the battery tends to get loosen Puma 110" SW
Post #63535 13th Mar 2011 2:31pm
lrmaniac
...ooops ... it did it again !!
for almost a minute it looked like my defender had no battery ... all the dashboard lights were off, with the ignition key in position to start ! :\ ... then suddenly it was allright ...
just went to the electrician to fit another trailer socket ... the green wire was smashed as well as the black wire ....
If this continues I'll have to take it to the dealer! Sad anyone experienced something similar ? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #64104 17th Mar 2011 7:01pm
Lorryman100
If it was a 12N socket then the green (Right Hand Indicator) and the black (Left Hand side Light) would only be live if the lights, indicator where on.
A 12S sockets green wire (live feed) and black wire (Earth) touching would short out and blow the inline 12v fuse.
On a new style 13 pin socket the green wire (Live feed) and black wire (Earth) would again short and blow the fuse. Did you check, pull the fuses after the socket was smashed?
Any more info on what was switched on at the time and what type of socket it was you crushed?
Post #64113 17th Mar 2011 7:39pm
lrmaniac
I was parking the Defender when I hit that hydrant ... It was a 7 pin socket ... the only thing turned on was the radio at the time ...
Did not chek the fuses because everything is working ... all lights, indicators, radio, AC ... nothing seems to be wrong ! Confused I've tightned the nuts on the battery, but they seemed OK ...
When this happened again this afternoon the starter engine did give a sign before the blackout .... but as all the dashboard light were out don't think that was the problem ... If it was the starter engine I would have lights on the dash wouldn't I ?
I'm starting to get nervous about this ... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #64119 17th Mar 2011 7:54pm
lrmaniac
Well ... I had repaired the tow socket and believed that the problem was fixed ...
But it happened again ... Confused
I turn the ignition and and have no lights on the dashboard, the car doesn't start, and canot even close it with the remote ... Checked the battery, fuses and everything is OK ...
Suddenly, I turn the key on again, after four or five times, and everything is normal .... Big Cry the car starts perfectly ... Could be something wrong with the imobiliser ? Could be the wiring to the winch, radio ?
This has happened alway after I use the remote, usually when unlocking the car ...
Did anyone experienced anything similar ?
I'm going to book the service (1yr/20000km - in my case one year) next week .... I wanted to have some ideas on how to explain and or ask them to check ... Crying or Very sad Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #66527 7th Apr 2011 2:28pm
110SEB
I'd check the battery earth as suggested. Get looking under the passenger seat!
Post #66589 7th Apr 2011 9:35pm
Grockle
the damaged socket could be shorting 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #66608 8th Apr 2011 8:26am
MK
I fixed the earth connection to the battery and since then never had a problem again. Puma 110" SW
Post #66617 8th Apr 2011 9:31am
as above i would check battery terminals are tight especially earth
Post #66618 8th Apr 2011 9:32am
lrmaniac
I've checked all that ... everything is tighten. Checked all the fuses on the right and left side. The tow socket was replaced ...
As far as I can see the wiring to the winch is intact ....
I believe that it could have something to see with the imobiliser .... because this always happens after I unlock the car ...
Could be Question Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #66631 8th Apr 2011 10:50am
