Home > My Defender > Proctas Defender 300TDI
Page 14 of 54 <123 ... 131415 ... 525354>
L110CDL
You must know by now if she has got a new mot, Procta Whistle Clayton.
Keeper.
Post #626711 24th May 2017 10:53pm
Procta
Well, sadly she has failed, got the call at about 4pm, while I was at work.
Rear Exhaust system not adequately supported (7.1.1)
Nearside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings top and inner of chassis (6.1.B.2)
Offside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
advisories
Steering box has a slight oil leak (2.2.D.2e)
Steering system has slight free play detected at steering wheel (2.2.A.1a)
Front Exhaust has a minor leak of exhaust gases (7.1.2)
Nearside Front Brake pipe slightly corroded (3.6.B.2c)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Nearside Front Panhard rod rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Panhard rod rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Rear Panhard rod rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Rear Panhard rod rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Oil leak ()
Offside Front Front wheel bearing has slight play (2.5.A.3c)
Nearside Gearbox mounting defective ()
Offside Gearbox mounting defective () Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #626723 24th May 2017 11:37pm
Procta
So looks like its a date with the welder there, I will pick her up tomorrow, and I will have a chat what the story is with the chassis. I am suspecting that it could have been just passed last year to be sold on.
brakes I am surprised it went through, the exhaust bracket at the rear I know about, which I suspected it would fail on, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #626724 24th May 2017 11:40pm
Procta
we are looking at 350 to weld her, Front bumper has to come off for the front end part, the rear section where its failed on needs a fabricating sadly. exhaust hanger the one that goes on to the rear cross member, needs one welding on. I did speak about getting a replacement cross member but that would require some work to do. Would really be best to fit a galv chassis if that was the story.
She is booked in for the week after bank hol, so we can get her sorted out and push forwards. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #626810 25th May 2017 12:36pm
Profyaffle
That's a real shame.. at least you can do the advisories at you leisure and the fail list wasn't too long.
Good luck with the repairs. 1993 200Tdi Defender 90
Post #626835 25th May 2017 2:10pm
Procta
yeah we can work through those anyway, with out any trouble as such, Gearbox mounts are next, mine are shot so that will be one less to worry about.
My mum has talked about lending me a few quid towards a new front bumper, but I will wait and see on that one. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #627124 26th May 2017 9:16pm
Procta
well got my replacement brackets for the exhaust on order, so fingers crossed those come tomorrow or Saturday, and that's it she goes in for a week or so for welding. Then we will see where we go from there, got some plans I want to do, But which one 1st, do I go back door, or brake upgrade , gearbox mount replacment and a service? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #628291 1st Jun 2017 8:46pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Important stuff first, cosmetics after. I would do the mounts and service then the brake upgrade with the rear door as a lower priority unless it's now falling off and being held on with black nasty and green string. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #628294 1st Jun 2017 8:54pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Yeah, I agree with the above, did they specify which which bits you need to rectify to pass? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #628308 1st Jun 2017 9:29pm
Procta
kit, it was these three
the brackets are on their way for the exhaust, I will have to strip the front down a little for the welding access.
Looks like the brackets for the gearbox are next on the cards then mash. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #628349 2nd Jun 2017 5:52am
Mash
Thumbs Up it's worth doing the safety bits first (MOT fails) then it's a rolling project, with that atleast you can enjoy her whilst you save for the next upgrade, too many people poor cash into wagons on cosmetics only to neglect the important bits i.e. Drivetrain/chassis etc. This leave the project parked up and they lose interest, lets not let that happen eh Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #628351 2nd Jun 2017 5:57am
Procta
sad thing is mash, she is my daily, I have had to revert back to my old daily until she is fixed . Another thing that's biting me, is the doe, This time last year I had over time coming out my arse! Now its basic flat rate now with very little over time Sad so things are a slow pace now cosmetics wise. I have to try and claw back the cash that I have lost with the fuel side of things, and the insurances Evil or Very Mad last month was well expensive! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #628510 2nd Jun 2017 4:53pm
Mash
Work I'm sure will pick up and you can buy the shinny bits again Thumbs Up unfortunately I never get "overtime" but I try to allocate enough cash each month to buy my bits. I can relate to insurance with multiple toys to insure Big Cry 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #628525 2nd Jun 2017 6:22pm
Procta
I have that much I want to do, its one of those things on what do I do 1st Laughing I do have a strong base here which is a cracking start.
Work will pick up but it could be next year, at the moment Nissan launching two new cars, new Leaf and the new juke, ( contracts for that is still work in progress) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #628632 3rd Jun 2017 9:18am
Profyaffle
It's unfortunate when things have to be done while you have plans for improvements elsewhere.. like my wobbly wheel that needs sorting before anything else.. Crying or Very sad 1993 200Tdi Defender 90
Post #628954 4th Jun 2017 8:35pm
