Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 42 of 81 <123 ... 414243 ... 798081>
L110CDL
Well i do hope you find it in the end, i think patients is the key here Wink Clayton.
Keeper.
Post #620917 1st May 2017 10:53pm
mk1collector
The intercooler has been swapped back to the original and an initial run around the block looks promising, I'll run it like this for a few days and if all is good I'll buy a new bas intercooler.
Original back in
I just need to put the front end back on now so I can drive around tomorrow. Ray
My build thread
Post #621100 2nd May 2017 7:49pm
L110CDL
I hope that the " promising " is still good after a few or so runs Ray Thumbs Up Clayton.
Keeper.
Post #621460 3rd May 2017 9:39pm
mk1collector
Still promising Thumbs Up you really don't notice gradual power loss until you get it back. It pulls like a train now Mr. Green Ray
My build thread
Post #621490 3rd May 2017 10:43pm
L110CDL
Really chuffed for you Thumbs Up Great the " promising " is holding up Wink Clayton.
Keeper.
Post #621493 3rd May 2017 10:54pm
mk1collector
Thumbs Up I'll keep the old intercooler in for a bit, but I keep looking at the bas hi flow ones and my trigger finger is itching Rolling with laughter Ray
My build thread
Post #621497 3rd May 2017 10:59pm
L110CDL
If you dont press that button soon, you will be losing a lot sleep, coz you know in the end that its the way to go and the best thing is, you need a new one Whistle Wink Wink Clayton.
Keeper.
Post #621498 3rd May 2017 11:04pm
mk1collector
That sounds right Rolling with laughter it's only the fact that I've already thrown around £1600 at it in the last two weeks on injectors, map sensor and fitting that's making me think I should wait a week or two just to be sure it's fixed. Ray
My build thread
Post #621500 3rd May 2017 11:10pm
L110CDL
That makes a lot of sense Ray Thumbs Up But the only downside i can think of is that, if you have " fixed " the problem, then there is no excuse to get a new intercooler ??????? Whistle Clayton.
Keeper.
Post #621502 3rd May 2017 11:17pm
mk1collector
Ahh well, that fix is only temporary as it's the standard size intercooler I've put back in as the allisport one had split, so I definitely need a performance one to replace that Mr. Green Ray
My build thread
Post #621504 3rd May 2017 11:20pm
L110CDL
With that reply then, i think that you will be able to sleep like a baby for a week or two knowing that your trigger finger will be activated Laughing Wink Clayton.
Keeper.
Post #621508 3rd May 2017 11:31pm
isacs
On the bottom of page 18 you sort out the right hand capping. You refer to something called stopper. What is that? mine need doing so remembered I'd seen it done in your thread.
Greg
Post #631440 14th Jun 2017 10:14pm
mk1collector
Hi Greg, stopper is a very fine body filler, usually used for finishing any pinholes left in the filler surface. After treating the corrosion on my capping it only needed a very light skim of filler so I went with the stopper. Thumbs Up Ray
My build thread
Post #631449 14th Jun 2017 10:48pm
isacs
Thanks Ray
I was going to use p38. I'll just get some of that instead as it's only a going to have few pit marks.
Post #631452 14th Jun 2017 10:58pm
mk1collector
Thumbs Up for small jobs I find it nicer to work with. Ray
My build thread
Post #631454 14th Jun 2017 11:01pm
