![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
The intercooler has been swapped back to the original and an initial run around the block looks promising, I'll run it like this for a few days and if all is good I'll buy a new bas intercooler.
![]() Click image to enlarge Original back in ![]() Click image to enlarge I just need to put the front end back on now so I can drive around tomorrow. Ray My build thread http://www.defender2.net/forum/topic17615.html |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
I hope that the " promising " is still good after a few or so runs Ray
Still promising
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Really chuffed for you
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
If you dont press that button soon, you will be losing a lot sleep, coz you know in the end that its the way to go and the best thing is, you need a new one
![]() ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
That sounds right
That makes a lot of sense Ray
Ahh well, that fix is only temporary as it's the standard size intercooler I've put back in as the allisport one had split, so I definitely need a performance one to replace that
With that reply then, i think that you will be able to sleep like a baby for a week or two knowing that your trigger finger will be activated
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
On the bottom of page 18 you sort out the right hand capping. You refer to something called stopper. What is that? mine need doing so remembered I'd seen it done in your thread.
Greg |
Hi Greg, stopper is a very fine body filler, usually used for finishing any pinholes left in the filler surface. After treating the corrosion on my capping it only needed a very light skim of filler so I went with the stopper.
Thanks Ray
I was going to use p38. I'll just get some of that instead as it's only a going to have few pit marks. |
