![]() | Home > Maintenance & Modifications > NAS rear step - fixing bolts |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
Just a few left!
Fitted two step bumpers in that past, both to station wagons with the seat belt mount bracing inside wheel arch and the anti crush tubes already present... ![]() 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
stuart123 Member Since: 03 Apr 2017 Location: Manchester Posts: 207 ![]() ![]() ![]() |
Awesome, thank you for looking.
You have mail... ![]() |
Thanks for that... it did look pretty shabby in that photo but having taken it off, its cleaned up really well and has since been shot blasted and powder coated and looks like new again
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Zim is so right...
The 'tin' plate under the Rubber Tread is not really up to it... ![]() Mine too a 3 years was all looking a bit sad, this was a basic make do and refinish, hopefully i'll replace the Tread Plate this year, removing the power coating in the process too, and refinish again. Still like the general product, just a few areas of substandard specification / material choice, oh and the finishing is... ![]() ![]() Click image to enlarge ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
sidewinder Member Since: 04 May 2016 Location: South Lanarkshire Posts: 9 ![]() ![]() |
Apologies for the tread resurrection.
I have a Nas step but didn't get the retaining stays that go back to the chassis with it. Could you possibly post up dimensions for the retaining stays and the additional cross brace between them to allow me to get something made up. Thanks |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
Hi there,
You'd need to say whether you have a 90 or a 110, and what age? I think there would be differences in the chassis and stays. I have an NAS fitted to my 110 and could provide some dimensions if that was any use. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks Donald,
Schoolboy error! I have a 1989 90. Hopefully someone can provide me with he corrected dimensions. Failing that what are the stays made of? Is it just flat bar or is it angle? If you could let me know the width and thickness of the angle / bar I could make something up. Regards |
No worries.
On mine (a 110) and, if my memory's right, on a friend's 90 which we took a NAS step from recently, the stays were steel box section, with a couple of angles. I haven't the car with me just now, but I could easily post pics later this evening. That said, I can't see any reason why some suitably robust bar wouldn't do the job - it works for the standard LR towbars. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks.
Pics would be handy if you get a chance. Cheers |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2285 ![]() ![]() ![]() |
A few of my soon to be replaced slightly rusty one on a MY16 90
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Many thanks.
Looks like inch bar 3-5mm thick will do the job.👍 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I'd suggest you want something thicker than 3 to 5 mm. That's only 1/8" to 3/16" in old money (to match your inch).
Thanks.
Do you happen to know the thickness and width of ones that come with the tow bar? I can fit the step and sort out the lengths. Cheers |
