Home > Maintenance & Modifications > NAS rear step - fixing bolts
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Hi all
I eventually managed to remove the remove nas step after working out I had to remove the rear qtr small piece of chequer plate which meant I could just (!) about get a spanner inside the rear cross member to hold the nut whilst I loosed the bolt.
The question is, how on earth do I get that nut back in there? I can imagine it must be near impossible.
The alternative is to buy longer bolts but I can imagine that could crush the near cross member and I can't see I could even get any distanced pieces inside them as described on Point 6 here... http://www.extreme4x4.co.uk/acatalog/LRM_i...racket.pdf
Suggestion welcome!
Post #617859 19th Apr 2017 9:11am
geobloke
Two things that Spring to mind. Can you A: weld a piece of rod on to the nut to help position it inside the cross member? Or B: fit a captive nut from the outside of the crossmember so negating the need for a spanner?
Post #617865 19th Apr 2017 10:01am
X4SKP
Hello stuart123
Photo's... Question
Do you mean the 2 fixing Bolts on the end of the NAS Step... Question
Mine go all the way through the Cross Member...
May be look to see if you can do the same...
Alternatively...a magnetic, ratchet ring spanner would probably hold the Nut sufficiently
in place to pick up the thread... Question
The Top Bolt holds the NAS Step...
Good Luck... SKIP
Post #617870 19th Apr 2017 10:10am
stuart123
Geobloke - even with a welded rod onto the nut I think I may struggle - good idea though. Just don't know how they got it on in the first place! Where would a captive nut go?! Not sure I follow that i'm afraid.
X4SKP - Sorry, no photos but yes, it is the fixing bolts on the end that you refer to and show in your photo... Interesting to see they go all the way through on yours. Looks like the bracket on the inside has been added to maybe spread the load across the rear member as I don't have that on mine...?!
Post #617871 19th Apr 2017 10:17am
Martin
Site Admin
Check you have the bit inside the end of the crossmember, looks like two tubes welded to a stick:
Part number KVX000020  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #617872 19th Apr 2017 10:24am
Martin
Site Admin
Do you have rear seats? Your profile shows a Puma CSW so you should, and therefore should have the bracket shown in X4SKP's photo as that's for the rear seat mount Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #617874 19th Apr 2017 10:25am
I think those bolts only go right through (and therefore have spacers) if you have forward-facing rear seats with the seat belt reinforcing bracket fitted.
You could try holding the nut in the ring of a spanner with tape, you could fit spacers and through bolts, you could fit Rivnuts from the ouside.
Post #617875 19th Apr 2017 10:28am
Martin
Site Admin
The NAS step is supposed to be fitted with bolts all the way through with spacers-on-a-stick:
Installation destructions: https://www.defender2.net/gallery/albums/u...Bumper.pdf  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #617876 19th Apr 2017 10:31am
stuart123
Thanks for all the replies - no rear seats so would explain why I don't have that bracket....
I don't think I have anything inside the rear cross member... I think if I did, the nut wouldn't have come out of there in the first place... looks like I need to order Part number KVX000020
Thanks for the instructions... my step is slightly different so assume not a Land Rover one.
Will work out how to upload a photo of it!
Post #617881 19th Apr 2017 10:45am
Martin
Site Admin
The KVX tubes are dear (£25 each!) so perhaps work out an alternative?
Pictures help: Uploading and Posting Pictures  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #617883 19th Apr 2017 10:50am
stuart123
Here it is.... not sure who makes it?
Edit: not sure how to get the images to actually load up rather than a link. Apologies.
Post #617885 19th Apr 2017 11:23am
stuart123
Ouch!! Yes...
Post #617887 19th Apr 2017 11:26am
Martin
Site Admin
Pic embedded for you - does look like aftermarket/copy.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #617889 19th Apr 2017 11:31am
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
That looks like the Masai version, slightly larger plates where the rod of the old style long jack fits and the tread is aluminium chequer plate.
I think i have some of the anti crush tubes (kvx000020) left over from fitting a style​ auto (OEM) step bumper, as they were already present. I'll have a look in the garage tomorrow if you like? Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #618033 19th Apr 2017 10:44pm
stuart123
If you do, that would be great, thank you very much...!
If not I will come up with an alternative options.
Stuart
Post #618116 20th Apr 2017 12:39pm
