![]() | Home > Maintenance & Modifications > Aircon Stainless Lower Grill? |
| jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790
[quote="K9F"]No rust on the ones I used to knock out before others jumped on the bandwagon.
Still got yours in the garage Mal for fitting my 110, was previously on the td5 double cab but I whipped it off and put the old scabby one back on before it went, not a mark on it 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Thanks Jomara,
Maybe I'll do another run on them after all? I had to change the spec as the first one at 3mm thick would have increased fuel consumption due to weight and was a complete b45t4rd to bend. It was good whilst it lasted and they sold like hot cakes! I can remember somebody trying to grasp a slice of the 'revenue pie' even then due to their success?
They went all over the World.... Treat every day as if it is your last....one day you will be right!! |
| adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299
Are we sure this is a Nak product? looks like the hole cutout is a different shape to the Nak one fitted to mine... These cutout holes appear square, whereas the holes in my Nak grill are oval... just a thought |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930
Definitely a different grille to the Nak one shown earlier and in Andy's photo James
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
I just removed mine, gave it a rub down and sprayed it silver. Coat of lacquer and refitted ... still looks great 5 years later and cost a few pounds to do
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582
That photograph of a grill put up by Mwd is a Nakatanenga grill. Yes it is a different pattern to the other photographs of different Nakatanenga grill.
A replacement grill has been sent to Mwd today. I do not have an explanation for why this has happened and will not give any BS explanation of what has happened. When we get it back we will send it back to Germany so they can inspect and try to understand Please note if anyone has an issue with an item supplied by us at 4x4overlander please let us know as soon as possible and if it is a reasonable issue we will do our best to resolve the issue. Brendan |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471
Kudos Sadly the old fix it yourself nature of Defender ownership seems to be a diminishing art. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264
I rubbed mine down and repainted but using zinga so it should not rust again followed by extreme chassis black from frosts and stainless hex bolts. Looks stunning.
Click image to enlarge 1953 80" 1987 mini city e 2011 90" |
| Mwd Member Since: 12 Jan 2016 Location: Scottish Highlands Posts: 45
Replacement Nakatenenga grille fitted today thanks to the very speedy replacement from 4x4 overlander. Looks good!
Click image to enlarge |
Did you pay extra for the rat?
| ob1conobe Member Since: 10 Jan 2014 Location: Gloucestershire Posts: 52
May I ask what fixings (specification) you used to attach it and where you got them from? Thanks. |
Bump
| YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648
To me, they look like M5 security head stainless steel bolts, probably about 1.5cm long.
They are available lots of places, e.g.: https://www.securitysafetyproducts.co.uk/s...s-fixings/ I used them for my Heritage mud flaps... don't want them going walkies!! YOLO... You Only Live Once... |
| Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182
Did anyone have any grief drilling out the old pop rivets. I’m using cobalt drill bits but they are as stubborn as anything.
Any tips? |
