Home > Technical > Offset Steering Wheel Spacer
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
Afternoon All,
1st post - great forum and was great use to me in researching prior to purchasing my Defender.
I was googling other Defender stuff and found by chance an offset spacer to go behind a 6-bolt steering wheel... to lift it up higher for better knee room (in the straight ahead position). Obviously worse with 180deg of lock on Wink
I cant remember where on earth I saw it, i have done loads of searches but cant for the life of me find it. All searches end up in discussions about wheel offset as in rims and tyres....
Thanks
Mike
Post #616531 13th Apr 2017 1:48pm
Miggit
Do you mean something like this? http://www.demon-tweeks.co.uk/Product.do?m...GwodnEoD9Q RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #616536 13th Apr 2017 1:54pm
Mike_E
Hi,
No that is just a concentric spacer... it shifts the wheel out but inline with the steering column.
The one I saw moved the wheel out by say 1", but also up towards the windscreen by half an inch or so. Down side that the wheel is lower when you then the wheel around 180deg.
Mike
Post #616540 13th Apr 2017 2:05pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Mike,
I suspect this is what you mean.....
http://www.4x4overlander.com/product/raid-...ting-ring/
Regards
Phil 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #616543 13th Apr 2017 2:22pm
X4SKP
Hello Mike_E Welcome Thumbs Up
Have you considered a Smaller Steering Wheel... Question better 'all' the way round (lock to lock) SKIP
Post #616552 13th Apr 2017 2:59pm
smb
Mike E,
Speak to Brendan(aka Leeds) as he advertises one on his website www.4x4overlander.com
Post #616553 13th Apr 2017 3:01pm
Mike_E
Ahhh that is it!
Thanks gents. Plan is to combine it with a smaller wheel too.... 6ft 5 you see....
Mike
Post #616555 13th Apr 2017 3:16pm
MaxRPM
I must admit that I thought this was an April fool until I saw the actual item advertised!
Post #616570 13th Apr 2017 4:22pm
X4SKP
MaxRPM...Me too... don't know if I like the idea of the Steering Wheel 'nodding' down left and right
when turned...It would look to add another level of vague Defender Steering IMO... Shocked SKIP
Post #616575 13th Apr 2017 4:53pm
Bluest
It seems a bit counter intuitive when you first come across the idea, but I've seen plenty of standard road car steering wheels where the rim is not concentric with the hub from the factory. Certainly some Citroens when they used to have one spoke, and some others I've seen but don't recall the brand. 2007 110 TDCi Station Wagon XS
Post #616578 13th Apr 2017 5:08pm
leeds
Well normally we like to try things out for ourselves first rather then just take manufacturers word for things..
Now the Raid offset/eccentric will give approx 10mm offset approx up, down, left, right.
Now we have one fitted to our white 90 with the offset to the left/inwards which gives us more elbow room for drivers right elbow.
For the majority of the time your steering wheel are pointed straight ahead. I have never noticed the steering wheel not being concentric when doing large turns.
If you suffer from fat thigh syndrome you could have the steering wheel effectively 'lifted' by 10 mm when driving straight ahead however 180 degree turn of steering wheel 10 mm lower.
Designed to fit Raid steering PCD.
Brendan
Post #616588 13th Apr 2017 5:49pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I'm pretty sure the original wheel is offset anyway with the top of the rim being further from the centre than the bottom of the rim.
Post #616625 13th Apr 2017 7:56pm
grafty99
Yes it is Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #616630 13th Apr 2017 8:03pm
