![]() | Home > Technical > Offset Steering Wheel Spacer |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 ![]() ![]() ![]() |
Afternoon All,
1st post - great forum and was great use to me in researching prior to purchasing my Defender. I was googling other Defender stuff and found by chance an offset spacer to go behind a 6-bolt steering wheel... to lift it up higher for better knee room (in the straight ahead position). Obviously worse with 180deg of lock on ![]() I cant remember where on earth I saw it, i have done loads of searches but cant for the life of me find it. All searches end up in discussions about wheel offset as in rims and tyres.... Thanks Mike |
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 ![]() ![]() |
Do you mean something like this? http://www.demon-tweeks.co.uk/Product.do?m...GwodnEoD9Q RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI |
Hi,
No that is just a concentric spacer... it shifts the wheel out but inline with the steering column. The one I saw moved the wheel out by say 1", but also up towards the windscreen by half an inch or so. Down side that the wheel is lower when you then the wheel around 180deg. Cheers Mike |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 805 ![]() ![]() ![]() |
Mike,
I suspect this is what you mean..... http://www.4x4overlander.com/product/raid-...ting-ring/ Regards Phil 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Mike_E Welcome
![]() Have you considered a Smaller Steering Wheel... ![]() https://www.defender2.net/forum/topic83242.html |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Mike E,
Speak to Brendan(aka Leeds) as he advertises one on his website www.4x4overlander.com |
Ahhh that is it!
Thanks gents. Plan is to combine it with a smaller wheel too.... 6ft 5 you see.... Cheers Mike |
MaxRPM Member Since: 15 Jan 2013 Location: South Staffs Posts: 1114 ![]() ![]() |
I must admit that I thought this was an April fool until I saw the actual item advertised!
MaxRPM...Me too... don't know if I like the idea of the Steering Wheel 'nodding' down left and right
when turned...It would look to add another level of vague Defender Steering IMO... ![]() https://www.defender2.net/forum/topic83242.html |
Well normally we like to try things out for ourselves first rather then just take manufacturers word for things..
Now the Raid offset/eccentric will give approx 10mm offset approx up, down, left, right. Now we have one fitted to our white 90 with the offset to the left/inwards which gives us more elbow room for drivers right elbow. For the majority of the time your steering wheel are pointed straight ahead. I have never noticed the steering wheel not being concentric when doing large turns. If you suffer from fat thigh syndrome you could have the steering wheel effectively 'lifted' by 10 mm when driving straight ahead however 180 degree turn of steering wheel 10 mm lower. Designed to fit Raid steering PCD. Brendan |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
I'm pretty sure the original wheel is offset anyway with the top of the rim being further from the centre than the bottom of the rim.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Yes it is
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
