Home > Td5 > Defender TD5 cruise control.....confused!
Page 3 of 5 <12345>
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
The red wire on the Speedohealer needs an ignition live, the black cable needs an earth which are besides the ECU. I cut the yellow/white wire coming from terminal B13 on the black ECU plug, connected the white wire of the Speedohealer to the speedo gauge end and the green wire to the ECU end.
The instructions to programme it are on Healtech's website https://www.healtech-electronics.com/ht_sh...or_en.html
Post #613754 1st Apr 2017 11:35am
ibexman
Cheers fella Thumbs Up Thumbs Up
Post #613755 1st Apr 2017 11:41am
Martin
Site Admin
For transfer box correction use it should be wired in either at the engine ECU or behind the instrument pack.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #613756 1st Apr 2017 11:43am
steve_c3
United Kingdom 2002 Defender 110 Td5 SW Epsom Green
Mines down near the ECU too, power and earth piggybacked from the vehicle and cut the yellow/white which carries the signal. Just make sure you connect it so the signal goes into the unit on the correct wire...few pics below if it helps.
This shows the unit, the white and green wires looped on the right are the feed wires...
This one shows the feed wires. If you look carefully, you should be able to trace the cable routing! I just cut the yellow/white wire near the ECU. Connect the vehicle feed to the White into the Speedohealer, connect the green wire (coming out the SH) back onto the yellow/white to the wire that feeds the ECU. The instructions it comes with are pretty good.
 2002 Defender 110 CSW TD5
Post #613878 1st Apr 2017 9:37pm
Martin
Site Admin
Thank you 😊  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #613881 1st Apr 2017 9:41pm
ashtrans
Site Sponsor
Hi All,
how do you know what to adjust the signal to ? as you are not changing the dash speed,
thanks,
Dave Dave
Post #698636 4th Apr 2018 8:52pm
ibexman
From a sat nav gps speed
Post #698651 4th Apr 2018 9:36pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
If you have discovery transfer box like me it’s - 15 % as this is the difference the transfer box makes
Post #698661 4th Apr 2018 10:04pm
DiscoSmiley
South Africa
Looks good. Let us know once you get it working. I still need to do mine.
Post #698682 5th Apr 2018 7:57am
amondeggs
Had mine working for over a year now. Works really well and is a huge bonus on long drives.
It made the 1000 mile non stop trip down to Spain last year much more bearable.
Great mod done using this guide Thumbs Up Thumbs Up
Post #698688 5th Apr 2018 8:35am
ashtrans
Site Sponsor
thanks but thats not what I meant, if you fit the 1.2 ratio, the speedo stays true assuming you keep the same speedo drive gear.
If you change the tyres you adjust the speedo healer to get the speedo true to a GPS but the question was what you set it to to 'fool' the ECU, not adjust the speedo but yes as 'amondeggs' suggests -15% is logical so the engine ECU knows no difference.
many thanks,
Dave Dave
Post #698731 5th Apr 2018 2:32pm
AJC
I’m now up & running. Thanks to Harry & Grafty
Post #716747 8th Jul 2018 5:52pm
mk1collector
Excellent Thumbs Up you just need one of these now Whistle
 Ray
My build thread
Post #716800 8th Jul 2018 11:03pm
AJC
All my switches are used so I have a darling switch above RHS speaker on dash
Post #716818 9th Jul 2018 5:20am
mk1collector
Finally got mine wired up today and on a few short journeys it seems to work perfectly Thumbs Up Ray
My build thread
Post #719512 24th Jul 2018 9:15pm
Page 3 of 5 <12345>
