![]() | Home > My Defender > Grafty's Td5 90 |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
They were. Although these are off a puma
The engine, chassis, axles and seatbox forwards is still original
Is putting your defender on the ramp to grease the prop shafts considered excessive use?
Usually do it on the floor but thought "why not?" 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
I'd wash it on the ramp too, no bending down! QRZ M8VPF
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
Grafty got the drl light stemp wired up till tomorrow
Click image to enlarge Click image to enlarge 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Look better in person doesn't photo to well 2008 110 2.4 XS Utility (Hagrid)
Looks good! Very bright
Well yesterday I had a very stark reminder. Change your wheel bearings in pairs!
On the way to the Defender Day at Pentille Castle ( got it this time Clayton This is the result (skip to 3 minutes in) https://drive.google.com/file/d/0BymT3xBHs...p=drivesdk No warning at all - If this had happened a couple of seconds later I would have been toast Thanks again to Clayton for the lift home 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Well I have started to strip the O/S front. Looking like a new stub axle is required
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
It is amazing that it gave no warning and no noise before hand as it looks pretty dry. Although I suppose the heat could have burnt off and remaining grease
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Time too check three more hubs
Well I changed the N/S a couple of weeks ago and checked the other 3 then. There was no indication of a problem when I checked which is the worrying part
I will remove all the hubs and re grease and internally inspect them all this weekend 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5376
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
| All times are GMT |
