Home > Td5 > Bang and judder
Rich1968
Bang and judder
Hi all.
So this has come from no where, fine 1 minute the next thing I know - driving as normal lift off the throttle I get a massive bang and judder from somewhere towards the front and the truck feels as though it's going to break in half.
Doesn't do it with the clutch pushed in or on the power.
Any thoughts?
Rich
Post #607355 6th Mar 2017 10:24pm
Hand brake shoes grabbing? Darren
Post #607367 6th Mar 2017 10:54pm
Pilgrimmick
Prop u/j? 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #607389 6th Mar 2017 11:40pm
geobloke
I'd go with a prop UJ too. they are the weakest point.
Post #607440 7th Mar 2017 7:35am
Rich1968
It's not the UJ,s. It's way to harsh for that. The whole truck feels like it's jumping in the air ( I know it's not, before someone kindly points it out Rolling Eyes )
Rich
Post #607443 7th Mar 2017 7:51am
rustandoil
Front diff?
Post #607445 7th Mar 2017 7:57am
geobloke
Possible, but if it were it'd most likely be bang bang judder all stop no drive. Certainly when mine went it pretty much bought the rear wheel off the ground and threw my passenger and I hard against the seat belts. Was only doing 30 mph as well.
If you do think it might be the front diff get yourself a telescopic pen magnet (the sort of thing used to retrieve lost washers or screws) undo your diffs filler plug and go fishing for shrapnel. If the diff is eating itself you will find shards, lots of them.
Post #607447 7th Mar 2017 8:04am
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
I'd wager the uj, if they get really worn they can almost snatch on themselves, just before the flailing prop shoots through the aluminium floor...! Pop it out n neutral, handbrake off, couple of bricks to stop rolling forward and give the props a good shake around. Bet it's your front diff one..
Cheers. Alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #607914 8th Mar 2017 7:56pm
JWL
It does sound a bit like mine before the front diff went completely, with mine I reckon it was when the broken part of the pin dropped out and caught in the planetary gears but got spat out of the way. A little later the rest of the pin dropped out and when the planetary gears dropped that's when it came to a sudden stop......... in the middle of the busiest road in Hereford in the evening rush hour.
Granted I got away with dropping the front prop off as both front half shafts weren't connected to the planetary gears as they'd dropped out and could freewheel quite happily, the prop flange however was wedged solid.
Post #607969 8th Mar 2017 10:02pm
geobloke
Is there any shrapnel in the front diff oil?
Post #608077 9th Mar 2017 8:46am
There are several different failure modes when the front diff fails. When mine failed, the differential locked solid but the crownwheel and pinion did not, so the only immediate effect was a near total inabiliy to steer. If the pinion and crownwheel also lock, you will get bangs, shudders, possibly a near immediate stop, possibly a catastrophic halfshaft or even propshaft failure. If the crownwheel disintegrates, you may get destructive noises and loss of drive, probably with a loss of steering as well.
The fact that your vehicle remains drivable (you say it doesn't do it with the clutch dipped or on power) makes me think propshaft UJ is more likely in this case. Any defect which causes this severe an effect should be easy enough to find though.
Post #608089 9th Mar 2017 9:58am
Rich1968
Thanks for the replies, will take a good look Sat am.
Rich
Post #608280 10th Mar 2017 12:00am
alwoodley72
Did you get sorted Rich?..
79 911 sc
Post #610831 20th Mar 2017 11:20am
Rich1968
I did but was hoping it would all go quiet so I didnt have to tell you. Embarassed
Rich
Post #610836 20th Mar 2017 12:12pm
alwoodley72
You can't dangle that carrot, Rich!.. what was it then, wheel not on properly...!
79 911 sc
Post #610862 20th Mar 2017 2:43pm
