Page 988 of 1392 <123 ... 987988989 ... 139013911392>
Sulisuli
Paul55 Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605001 26th Feb 2017 7:13pm
ericvv
custom90steve wrote:
Eric - looks perfect! Thumbs Up How do you keep your windscreen seal in such perfect condition?
Mines starting to perish. Neutral
Don't know really. I do not use anything specific really other than a commercial rubber treatment spray or silicon spray, but not more than twice per year. My seals are all like new, no cracking or other aging signs at all. Now, 8.5 years old and 85K km, so it has been used. But, it never is parked really outdoors, I'd say 80% in dry garage, 20% under carport, limited direct sunlight, never at the seaside, so no salty winds. And it obviously is kept very clean. I don't know if some or all of those factors combined help keep it in condition, but nothing else I can think of really.
Eric
Edit - below is a picture of what I use a few times per year. But I have asked the question a few times if it is really effective to spray something on a thick rubber seal. It surely does not penetrate in our window seals, so is it really doing something? I never got a clear answer to that...
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #605002 26th Feb 2017 7:15pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I use some stuff I found in bedside cabinet for treating the rubber bits Shocked
Post #605009 26th Feb 2017 7:34pm
Sulisuli
Do Anne Summers do car cleaning stuff Rolling with laughter Rolling with laughter Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605027 26th Feb 2017 8:02pm
mk1collector
My youngest needs to learn to ride on two wheels this year so picked this 2nd hand bike up today in the defender for her to learn on Mr. Green she likes the colour pink and land rovers so this fit the bill perfectly.
 Ray
My build thread
Post #605064 26th Feb 2017 9:17pm
Michaels Defender
United Kingdom 2013 Defender 110 Puma 2.2 ST Corris Grey
I modified my side vent today
I damaged the plastic pegs while removing the side vent last time, so I drilled the pegs out and screwed it on using black stainless screws, I also blanked of the vent as I have a ITG air cleaner and the vent is redundant
Thumbs Up
Post #605793 1st Mar 2017 6:27pm
excossack
Started fitting a Albright, heavy duty master cut out solenoid into the battery box. Rain stopped play.
Gave the brackets for the dog guard a coat of primer and then a top coat - now drying in the shed.
Removed the rear carpet and foam mat as water had made its way through the rear side windows Sad another job for tomorrow. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #606691 4th Mar 2017 6:01pm
nicholas2012
Scotland 2010 Defender 90 Puma 2.4 HT Tamar Blue
Took my old mk4 astra to the scrapyard today about 20miles away but ended up bringing it back with me as was abit too late, they closed earlier than i thought Embarassed
But got a good few waves off fellow defender drivers Cool
Post #606726 4th Mar 2017 9:50pm
Stacey007
My dad came round and what we call the 'bad garage' at the back of house where my New toy will go we changed the up and over door for barn doors... so it should fit in.
So I then cleaned my other car and one of my dads Smile
Post #606744 4th Mar 2017 10:21pm
Retroanaconda
Nice. Though you've hung them back to front Whistle
Post #606749 4th Mar 2017 10:35pm
Stacey007
oops really...
My dad did think about this for a bit and decided the way we did it... Smile
Oh well they seem fairly solid and look far better than the old up and over,
Don't think is should make too much difference?
Thumbs Up
Post #606752 4th Mar 2017 10:44pm
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
That's what I thought.
Yeh, swap em over before too long. 2009 2.4TDCi XS Utility Wagon.
Post #606759 4th Mar 2017 10:49pm
Thumbs Up
It will drop, as there is no upwards 45 degree bracing to counteract the force of gravity. Laughing
Typically there is a single upward facing brace or a K brace. I prefer the latter on gates and doors I've made before.
A K bracing with triple hinges.
But yes, swap those over. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #606768 4th Mar 2017 10:57pm
Retroanaconda
Your braces are operating in tension, whereas you want them working in compression.
Swap them over and put three hinges on each - in line with and attached to the rails, not the panelling.
Post #606856 5th Mar 2017 10:31am
Rashers
Hope the John Deere pedal tractor gets a new home when it is evicted?
Post #606858 5th Mar 2017 10:36am
