L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
Good news there Steve
![]() Procta, i think you have a really bad spaghetti junction there ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Went off-roading with the Suffolk landrover club at the weekend, got some great tuition from some experienced trials drivers and then gave my 110 some proper use. I am absolutely amazed at what a stock utility will do on bfg 255 85 s even if they do rub a bit. Better sort out a 2 inch lift then.😁 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
Series 3 tailgate delivered and some trees felled at work so free fuel also
![]() ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Is that Beech? Looks a bit like it. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Im amazed they did anything for 37!! Mike |
Well it is only 2 screws per headlight.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
They adjust both screws!
I had an argument with them after waiting 2 hours and guessed the alignment, when they wanted to book it in so they could "strip it down" to adjust...i pointed out they didnt need to, but what do i know! I think it could probably do with some realignment - but it will need to wait until i can be bothered and find someone Mike |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Any MOT testing station can do it for you mate... YOLO... You Only Live Once...
I know - i probably trust them less
Yeah, it's pretty much got to be an MOT station with the right equipment.
Pretty sure it's the same it's or without H/L levelling, just needs to be set to zero if you do have it. Mine however does not, kinda glad as they can be a pain in themselves. Went out last night for a test and they are indeed aligned perfectly now. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Mine does have H/L
It was the up/down on mine drivers was too low so ive adjusted it to the same as the PX...the passengers needed moving up (real world comparison) so ive done that too. I would be interested to see a picture of your light spread - i should be able to check mines spot on. - no ones complained at dazzle including the wife in her car (as a test) Mike |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 607 ![]() ![]() ![]() |
Gave the Landy a good hose down and fitted the glove box conversion I've had rattling around behind the seat for the last month.
Wish I hadn't bothered - looks rubbish. ![]() Hoping the steering guard and are wheel carrier look better when they go on..... https://instagram.com/bentheoandrews |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Well another step towards getting back on the road but a long way to go still... ![]() Click image to enlarge It all looks a bit empty now... ![]() Click image to enlarge |
Great to see the next step has been made, many thanks for the update
