Home > Td5 > Fan - all or nothing
Welkman
Hi,
My fan in the defender is either on or off with no modulation. Is this normal or should it be adjustable? I have lived with it for three years now.
Thanks
James
Post #599957 7th Feb 2017 9:19pm
Gareth
Well you have seen up in my other post, but in standard form, the lever on the left has a 2 speed fan switch incorporated. Speed one is like a gnat farting though the vents, speed 2 is like Sir Alex Ferguson in a bad mood! As you move the lever up to the top it closes the fresh air flap completely.
With the Landrezieger mod, the air flap cable is left disconnected in the open position, and the complex switch lever assembly is replaced by a simple variable resistor, which talks to a PWM controller that sits under the bonnet, and controls the fan. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #599968 7th Feb 2017 9:44pm
Welkman
Yep I understand the benefit of the mod I am just wondering if I should have had more than the one setting in the first place Smile
Post #599971 7th Feb 2017 9:52pm
grafty99
There are 4 settings in total.
1) fan off fresh air flap closed
2) fan off fresh air flap open
3) fan low speed
4) fan high speed
Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #599987 7th Feb 2017 10:52pm
miker
Really?
Mine, and other defenders I know, have only 3 detented positions on the handle.
Off (and closed)
Low speed
High speed
Post #599992 7th Feb 2017 11:11pm
grafty99
Mine has closed and off right at the top. Then move it down and the flap opens before the first speed. Then down to first speed and full speed etc. That is how it should work if the cable is correctly adjusted Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #599994 7th Feb 2017 11:17pm
AndyB
1989 Defender 90 300 Tdi HT Cairns Blue
Just had a look on eBay
http://www.ebay.co.uk/itm/60A-DC-Brushed-M...SwjDZYd-5t
What is your opinion on trying something like this? Seeing as we have a 'rather older' 90, the control knob would not look out of place sticking out of our dash!
Andy
Post #600031 8th Feb 2017 8:54am
Gareth
It's worth a go, but I wanted to keep mine looking as standard as possible. You would have to make your own wiring up with this I presume? 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #600036 8th Feb 2017 9:13am
bankz5152
My 90 was
Off
Low
High
My 110 XS seems to be
Off
Very low - If I leave it inbetween low and off, probably a fault but its quite nice
Low
High
Post #600061 8th Feb 2017 11:12am
Welkman
Ah ha I have figured out that I am missing the high mode so I guess it is time to adjust the cable !
Post #600098 8th Feb 2017 1:46pm
grafty99
The cable only controls the flow of fresh air into the heater system. If you have only one fan speed it will be either the dash switch or the wiring at fault Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #600122 8th Feb 2017 4:31pm
