![]() | Home > Td5 > Fan - all or nothing |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142
Well you have seen up in my other post, but in standard form, the lever on the left has a 2 speed fan switch incorporated. Speed one is like a gnat farting though the vents, speed 2 is like Sir Alex Ferguson in a bad mood! As you move the lever up to the top it closes the fresh air flap completely.
With the Landrezieger mod, the air flap cable is left disconnected in the open position, and the complex switch lever assembly is replaced by a simple variable resistor, which talks to a PWM controller that sits under the bonnet, and controls the fan. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333
Yep I understand the benefit of the mod I am just wondering if I should have had more than the one setting in the first place
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
There are 4 settings in total.
1) fan off fresh air flap closed 2) fan off fresh air flap open 3) fan low speed 4) fan high speed 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
Really?
Mine, and other defenders I know, have only 3 detented positions on the handle. Off (and closed) Low speed High speed |
Mine has closed and off right at the top. Then move it down and the flap opens before the first speed. Then down to first speed and full speed etc. That is how it should work if the cable is correctly adjusted
| AndyB Member Since: 10 Nov 2016 Location: North Wales Posts: 37
Just had a look on eBay
http://www.ebay.co.uk/itm/60A-DC-Brushed-M...SwjDZYd-5t What is your opinion on trying something like this? Seeing as we have a 'rather older' 90, the control knob would not look out of place sticking out of our dash! Andy |
It's worth a go, but I wanted to keep mine looking as standard as possible. You would have to make your own wiring up with this I presume? 2021 Defender 110 X-Dynamic HSE D300 MHEV
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
My 90 was
Off Low High My 110 XS seems to be Off Very low - If I leave it inbetween low and off, probably a fault but its quite nice Low High |
Ah ha I have figured out that I am missing the high mode so I guess it is time to adjust the cable !
The cable only controls the flow of fresh air into the heater system. If you have only one fan speed it will be either the dash switch or the wiring at fault
