Home > Maintenance & Modifications > Replacement steering wheel grief.
Page 1 of 3 123>
petestaunch
United Kingdom 2008 Defender 110 Puma 2.4 HT Keswick Green
Continuing the theme of a new Defender owner who bought things prematurely and is trying to sort it out after the fact!
I bought a steering wheel on ebay.
Seller quote 'Has been on a TD5. Believe 48 splines but not sure'
It doesn't fit my 2008 Puma.
The guts.
What do I need to buy to make it fit? Is it worth the effort?
Thanks
Post #598274 1st Feb 2017 3:37pm
Stacey007
It looks to be 48 splines counting the sprockets.
I like the look of it (if it will fit a series) Thumbs Up
Good luck fitting it you may need a Boss but I'm not sure? is there any name / make on the wheel you can look up?
Post #598276 1st Feb 2017 4:03pm
X4SKP
Hello petestaunch
A 2008 Station Wagon looks to be a 36 Spline...but the Steering Wheel looks good so maybe source a replacement Boss and you can use it...check the PCD (Hole Positions) for any swap over Boss, pairing it to your Wheel
Good Luck SKIP
Post #598277 1st Feb 2017 4:10pm
gabe3105
Judging by that table then, his hard top will be 48 spline, but the steering wheel in the picture is 36?
Post #598280 1st Feb 2017 4:38pm
miker
By my count steering wheel looks to be a 36 spline as would make sense for for a td5.
The puma could be 36 or 48 dependent on version, but as it doesn't fit you can assume 48!
Should be able to source a 48 spline boss that will mate to your wheel.
Post #598303 1st Feb 2017 6:14pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Looks like a Mountney Classic wheel, why not give them a call Thumbs Up
http://www.mountneyltd.com/2014-08-18-04-2...ssic-range 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #598309 1st Feb 2017 6:36pm
petestaunch
Again, possibly moronic question but I am just counting the little ridges, correct? In that case it's 36 spline.
I was just told by the mechanic that 'it wouldnt fit'. Is there any other reason it wouldnt fit?
Thank you all for your help, and yes it looks like a Mountney. Heading to their site now
Post #598493 2nd Feb 2017 9:38am
X4SKP
Re: Replacement steering wheel grief.
Hi petestaunch
Your replacement wheel is fitted with a 36 Spline Boss (yes the 'ridges' are counted)
If it doesn't fit your Defender then you (probably) have a 48 Spline Steering Column
(Take the existing wheel off and count the Splines on the Column)
36 Spline Boss
As it's easier to change the Boss than your Steering Column your options are:
1 Change the Boss to a 48 Spline Unit
2 Sell your Replacement wheel and start again
3 Do nothing
You have to answer your initial question...
Good Luck SKIP
Post #598544 2nd Feb 2017 12:28pm
petestaunch
Skip.
Appreciate you taking the time. Thank you.
Pete
Post #598547 2nd Feb 2017 12:31pm
X4SKP
That's OK, I really like your replacement wheel...so if it were me, i'd sort this out so it could be fitted... Thumbs Up SKIP
Post #598551 2nd Feb 2017 12:43pm
petestaunch
Right
Mountney werent very helpful. Could someone please just post a link to a suitable boss. I dont think I need one made out of Carbon Fibre or anything crazy.
Thanks
Pete
Post #598611 2nd Feb 2017 5:00pm
miker
If you can measure the pcd then yes.
PCD being the size of the circle that all the bolts sit on the perimeter of.
Post #598621 2nd Feb 2017 5:50pm
petestaunch
Post #598631 2nd Feb 2017 6:19pm
X4SKP
Measure the PDC of your location screws then check with any Boss supplier
This may work...
http://www.exmoortrim.co.uk/land-rover-48-...0-vat.html
Download the Installation Advice also
 SKIP
Post #598634 2nd Feb 2017 6:28pm
jomara
Here's the 48 spline Mountney boss on LRParts Thumbs Up
http://www.lrparts.net/defender-steering-w...lines.html 2014 110 2.2TDCi XS Station wagon
Post #598651 2nd Feb 2017 7:05pm
Page 1 of 3 123>
