![]() | Home > Maintenance & Modifications > Replacement steering wheel grief. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3849 ![]() ![]() |
It looks to be 48 splines counting the sprockets.
I like the look of it (if it will fit a series) ![]() Good luck fitting it you may need a Boss but I'm not sure? is there any name / make on the wheel you can look up? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello petestaunch
A 2008 Station Wagon looks to be a 36 Spline...but the Steering Wheel looks good so maybe source a replacement Boss and you can use it...check the PCD (Hole Positions) for any swap over Boss, pairing it to your Wheel ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
gabe3105 Member Since: 25 May 2015 Location: Grimsby Posts: 237 ![]() ![]() |
Judging by that table then, his hard top will be 48 spline, but the steering wheel in the picture is 36?
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
By my count steering wheel looks to be a 36 spline as would make sense for for a td5.
The puma could be 36 or 48 dependent on version, but as it doesn't fit you can assume 48! Should be able to source a 48 spline boss that will mate to your wheel. |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Looks like a Mountney Classic wheel, why not give them a call
![]() http://www.mountneyltd.com/2014-08-18-04-2...ssic-range 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
petestaunch Member Since: 19 Nov 2016 Location: Wales Posts: 65 ![]() ![]() ![]() |
Again, possibly moronic question but I am just counting the little ridges, correct? In that case it's 36 spline.
I was just told by the mechanic that 'it wouldnt fit'. Is there any other reason it wouldnt fit? Thank you all for your help, and yes it looks like a Mountney. Heading to their site now |
Hi petestaunch
Your replacement wheel is fitted with a 36 Spline Boss (yes the 'ridges' are counted) If it doesn't fit your Defender then you (probably) have a 48 Spline Steering Column (Take the existing wheel off and count the Splines on the Column) ![]() Click image to enlarge 36 Spline Boss ![]() 48 Spline Steering Column As it's easier to change the Boss than your Steering Column your options are: 1 Change the Boss to a 48 Spline Unit 2 Sell your Replacement wheel and start again 3 Do nothing You have to answer your initial question...
Skip.
Appreciate you taking the time. Thank you. Pete |
That's OK, I really like your replacement wheel...so if it were me, i'd sort this out so it could be fitted...
![]() https://www.defender2.net/forum/topic83242.html |
Right
Mountney werent very helpful. Could someone please just post a link to a suitable boss. I dont think I need one made out of Carbon Fibre or anything crazy. Thanks Pete |
If you can measure the pcd then yes.
PCD being the size of the circle that all the bolts sit on the perimeter of. |
Measure the PDC of your location screws then check with any Boss supplier
This may work... http://www.exmoortrim.co.uk/land-rover-48-...0-vat.html Download the Installation Advice also ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
Here's the 48 spline Mountney boss on LRParts
![]() http://www.lrparts.net/defender-steering-w...lines.html 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
