Home > Maintenance & Modifications > Nakatenenga safe
BigMike
Nakatenenga safe
Does anyone have one of these? If so would you mind sticking up a pic of how it sits in the vehicle with cubby on top? I ask because there are no shims on the base to lift it to the horizontal. Quite like to know if you had to drill any further holes in it or put in more riv nuts in the vehicle floor. Also interested in where the top right hand corner (for rt hnd drive vehicles) of the cubby sits and if you find it a problem for your left elbow
I have emailed Peter to ask some other questions about it but if anyone has one I'd appreciate the above.
Post #59186 15th Feb 2011 11:17am
BigRuss
I'll give you some info tonight mate. Russell
2011MY 110 XS USW Black
Post #59188 15th Feb 2011 11:21am
BigMike
Thumbs Up
Post #59196 15th Feb 2011 11:50am
BigMike
Actually Russ, totally forgot about this http://www.defender2.net/forum/topic4990.html?highlight=heater
It's definitely too high (for me) in current form with the cubby box in position. My left elbow will be knackered in no time if I fit it that way, there's just not enough room. Spoke to Exmoor Trim to see if they could re-trim a cut down cubby box so am waiting on an answer. WIll have a ponder - it's quite a bit of modification to make this work really.
Post #59198 15th Feb 2011 12:10pm
Glynparry25
When I fitted my Front Runner under cubby box safe I found the same problem..... For the first couple of months I hit my elbow on the corner of the cubby box when putting the hand brake on... and on a few occasions I even caught my funny bone Banging Head But now I have got used to it Mr. Green
Glyn Dog Sheep
Post #59203 15th Feb 2011 12:56pm
BigMike
Glyn does the FR one sit beneath the floor? ie you have to remove the panel and the floor of the box sits in space above the transmission tunnel?
Post #59204 15th Feb 2011 1:00pm
Glynparry25
Yes it does.
You have to take out the blanking plate that is there and turn the clamps that hold hoses across the transfer box upside down.
TBH the space created by going down is only enough to hold the defenders service portfolio.... the most space is created by it extending up.
Glyn Dog Sheep
Post #59205 15th Feb 2011 1:03pm
BigMike
I looked at the FR safe and decided it wasn't big enough. Plus I want to put a heater in mine and it should fine fine in the Naka one, but the cubby height is a problem, I need to have a think about that.
Post #59209 15th Feb 2011 1:15pm
Lorryman100
BigMike wrote:
Nakatenenga safe
I posted this on, "What did you do in your Defender today", section when I fitted mine. Did not want to drill any more holes in either the safe or the floor as I am still thinking of locating the Eberspacher heater there, or under the rear seats. Not sure yet hence the reason for not fixing any more riv nuts!
Lorryman100 wrote:
Here is how I fixed it in place:
1. Took out original cubby boxes 4x machine screws and removed cubby box.
2. There are two timber angled lengths affixed to the bottom of the cubby box held on with 3x staples and glue. I carefully removed them just in case and tapped the staples legs flat.
3. Took the safe out to car and test fitted it. First problem is that only two of the fixing points on the car are available, the rear two as the front two fixing points are under the power sockets which is fresh air.
4. Placed cubby box on top of safe and found the holes were close enough. Used M4 machine screws and washers and lined the two up. I then tightened the front two bolts tight enough as not to distort the metal top plate on the safe to let the key lock mark the bottom of the cuddy.
5. After undoing the bolts and lifting of cubby saw that the bottom was marked for drilling the access hole for the lock. Used a forstner bit and drileed the hole. matched up the safe and cubby box and found everything lined up...TF.
6. Took the now complete assembly out to car and sat it between the seats. Found the top of the cubby box was not level and when you use only the rear fixing points the front lifts up and vibrates.
7. Took the complete cubby box out and placed the original timber angled lengths( see note 2..... TF) back onto the floor and used the front two fixing bolts to fix them in place. Tightened them right up so the head was buried into the timber.
8. Placed the completed cubby box back into place and fixed the rear bolts. Then used two self tappers into the timber rails at the front fixing point. Whole unit now solid and level.
Once the weather clears up and I can get into the garage I will make a couple lengths of steel with the angle set and weld on a nut to allow me to use the 4 fixing points on the safe with bolts.
Post #59231 15th Feb 2011 5:25pm
BigMike
Cheers Brian
This begs the question as to why Peter set it up in this way? It needs to be level, but there are no shims on the base. It needs 4 fixing points, but only the rears are able to be used and with the rears its still very close to the front. I also found when playing about with the position, that a better place is further back - after all the safe has a "step" at the back to get it over the flange in the floor/the bulkhead bar. If the rear points are used in the vehicle floor, the cubby when lined up on top is awkward for the elbow, yet further back it's fine. I also think it would be better if the cubby was cut down from the top to make it more shallow, but in terms of getting someone to do this I'm drawing a blank so far. I could do the cutting myself but then it needs an upholsterer to re-trim, so everything starts to get expensive.
Maybe one way to deal with it is to keep it further back by using two lengths of bar stock, say 50mm by 2mm and whatever long - use the four LR fixing points by drilling through the bar stock and fixing it to the floor riv nuts at the front, then safe to bar with the already cut front safe holes, then some shims under the safe at the points where the rear riv nuts are located, through the bar again etc.
The Epersbacher will fit in there definitely. I want to mount my CB in there as well, probably side on towards the driver, then run the mic wire to a panel mount in the front of the safe on the left side so the mic cable socket can plug straight into the box. Putting on the drivers side will bring it a little close to the transfer box lever I think. Also with shims installed it gives the issue of the exhaust and inlet going through both safe and floor, but there being a small gap between.
Post #59236 15th Feb 2011 5:48pm
BigRuss
Well after you started talking about cutting the cubby box down you got me thinking. Now the cubby box is clad in leather which is only stapled in place as you can see underneath, no I would think that if you remove the inner lining you would find that the inside would also be stapled.
So if you were to remove the inner lining (and the lid) and then remove the staples from the leather and pull it back to give you enough room to make the cut required. Then just simply replace the leather and then with it attached at the bottom just pull it inside nice and tightly. You may have to make some small snips in the corners inside the box so it fits better.
So tools requires are; a screw drivers, a staple gun, staple remover and a saw. Oh don't forget a tap measure and remember measure twice and cut once.
Russell Russell
Post #59243 15th Feb 2011 7:22pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Prompted by Gly's comment above and partly out of curiosity as to whether a Webasto would fit under, I removed the cubby box and blanking plate. There's not much room above the transfer box but if you could move the fuel lines and fabricate a box for the heater/safe there's quite a bit of room behind the transfer box.
[/img]
Post #59247 15th Feb 2011 7:38pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
can anyone tell me the total height from the base of the safe to the top of the cubby box ?
thanks
CR
Post #59255 15th Feb 2011 8:01pm
BigMike
Russell
Needs a new lid, since the cut would lengthen the aperture on the top. Not difficult though Thumbs Up
I have a free weekend this weekend, so will make some shims and take a more detailed look at the stock cubby box
Post #59257 15th Feb 2011 8:04pm
BigMike
thanks
CR
safe dimensions are on the naka website and I guess you can measure your own cubby box Thumbs Up
Post #59261 15th Feb 2011 8:07pm
