Home > Off Topic > Anyone here install electric underfloor heating?
AJC
If so, can i just have a bit of advice please.
I want to install into my en-suite, at the moment i've a chipboard floor, i have been told to put a plywood on top of this, is that correct?
And does the wood floor need an primer/paint seal?
Thank you
Post #578368 17th Nov 2016 8:58am
DAZ110
I used this a approx 5 years ago in my lounge with their insulation:
http://www.1926woodflooring.co.uk/acatalog...ments.html
Not for bathrooms though.
This might be better in your en-suite?:
http://www.1926woodflooring.co.uk/acatalog...ating.html
Post #578382 17th Nov 2016 9:57am
gabe3105
I think your advice is correct. You need to make sure your chipboard floor is well screwed to minimise movement. I would be tempted to use a specialist tile backer board like hardie backer or no more ply, rather than standard ply (I assume you will be tiling over it?). They have the benefit of being only 6mm thick too so are useful if floor height is an issue between different rooms. No prime required. Be careful if tiling directly on top of the wires as it is easy to damage them with a trowel...
Post #578385 17th Nov 2016 10:03am
andy---doe
Rather than ply use Thermal Tilebacker Boards. These fix to your current floor and will send the heat upwards (rather than into your floor) and also level your floor the same as ply.
Loads of different ones but example:- https://www.tlc-direct.co.uk/Products/BNFB...0wodpQ4Evw
Post #578392 17th Nov 2016 10:30am
RED-DOT
En-suites and underfloor heating in a Defender. What a great idea! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #578404 17th Nov 2016 11:11am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I have just done our ensuite (concrete base) and got all the stuff from here.
http://www.theunderfloorheatingstore.com/
Load of tips and videos to help.
Post #578413 17th Nov 2016 12:10pm
Martin
Site Admin
Moved to Off Topic - the "General" forum is not a dumping ground Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #578420 17th Nov 2016 12:53pm
AJC
Scott, thats where i bought it from, i have just ordered the backing board from them and a bottle of primer, thanks for your help everybody, much appreciated.
Post #578428 17th Nov 2016 1:30pm
RED-DOT
I drive concrete mixers and have covered acres of underfloor heating systems and the professional layers use a product called Durament or Hyflo concrete. It is a by product from power stations sourced from Germany. Zero stone just sand durament and super plasticiser applied at almost treacle like consistency and self levelling. Use in flats, schools and offices and usually top end homes. It is a joy to see it turning a bare building into a finished floor. £250PCM approx. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #578435 17th Nov 2016 1:58pm
